View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 [81] 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134
  1. what to do with fitted cases????
  2. 11 Gauge Aluminumn Forming
  3. Scraping a lathe bed
  4. Bad day at work
  5. 2 speed reversing switch 3 phase motor
  6. direct drive or belt??Alistair
  7. OT Mig Wire Properties ...
  8. Want List
  9. Step jaws are done. Is step big enough?
  10. Iron Castings
  11. Grizzly Power Feed Bummer
  12. Simple solution to a tough problem...
  13. Cast iron crack suggestions?
  14. Thread Strength - different materials
  15. Another shaper
  16. Shop Roof Leaks
  17. Anti-galling lubricant for ally
  18. Need to fit a square peg in a round hole
  19. need help with SB 7" Shaper Gib/Oil/Pump
  20. Lodge & shiply Lathe??
  21. South Bend 13" weight
  22. Cross Slide Screw
  23. Woodworking dovetail jig??? You made one??
  24. Somewhat OT: Preserving old newspaper clippings?
  25. grooving on a big hunk of Delrin
  26. How Level is Good Enough?
  27. tp grinder pics
  28. Gap bed, anybody ever use that feature?
  29. Stuff Happens
  30. Welding on lathe stand
  31. Tilting Angle Table
  32. mill is running beautifully now thanks guys
  33. what's wrong with this
  34. Semi - O/T A little antique work
  35. Sandblasted collets and cutters anyone
  36. F1/ot
  37. New toy from junk store
  38. OT? Saw for Wood
  39. Thought I would check in
  40. centrifuge pics
  41. Magnifier for optical center punch (pics)
  42. how to cut a metric thread!
  43. Pipe threading via H.F. power threading machine
  44. Personal Shoptask Site
  45. Cleanup reaming my tailstock bore?
  46. South Bend Vertical Mill - vintage catalog info
  47. Looking for an old post
  48. HF 3.5 gal parts cleaner + Simple Green?
  49. HF Carbide Grinder and Work Station.
  50. PM sure has gotten strange, and down
  51. Grinder work head finished
  52. Guitar Truss rod
  53. End Mill Grinding/sharpening
  54. V-Twin update
  55. Just a thank you
  56. Deep Hole Drilling Revisited
  57. OT- Firefox or IE
  58. Busy Bee Lathe
  59. What are Module or Diametrical Threads?
  60. OT, email dates gone crazy
  61. Metal Spinning Tools - What and How To Make?
  62. Machinery Move
  63. Making a 5C collet adapter, have a question
  64. schrink fitting
  65. Thread vs Rethread
  66. Pratt Burnerd 4 jaw - jaws are TIGHT
  67. sight is finished
  68. AC Induction Motor Poles
  69. Fuel burner for forging etc.
  70. You know you are a HSM when?
  71. Drop Bed Trailers
  72. OT-Anything near Gatlinburg,TN
  73. New Crossfeed Nut for Atlas Lathe
  74. Buying a new lathe and I have questions?
  75. looks impresive for the money w/work cnc router
  76. OT Hey David, Which Ear?
  77. knurling without oil???
  78. Bridgeport serial #?
  79. Thread not tracking
  80. Cutting Shim Stock
  81. Pine Wood Derby update
  82. Rewinding Armature & Magnet Wire?
  83. ot auto air conditioners
  84. FrankFord, voice of experiance, I should have known
  85. OT: I awoke this morning to find all my "favorites" missing?
  86. Trustee from the Toolroom
  87. Harbor Freight Portapower Sets - Are They Worth Buying?
  88. Enco Free Ups Shipping Code April
  89. eBay Angle Block and Parallel Set
  90. Hex stock
  91. Are all machines she?
  92. OT: electronics parts
  93. (OT) What's My Line?
  94. Fine Wood Working
  95. Timing Belt dividing Head
  96. home based machine shop business ( Long )
  97. Tap
  98. Arkansas stones and India stones
  99. MAXIMAT V10 milling attachment
  100. Print Reading Help
  101. PAK 5XR Plasma Cutter Info
  102. End Mill Holder for a Lathe
  103. Lathe work technique question
  104. rf31 quill problems
  105. Newbie setup question?
  106. Couple shop-setup style tips...
  107. How s this for a mill
  108. Harbor Freight coupons?
  109. good buy or goobye
  110. OT: Are you autistic?
  111. Tapping Stainless Steel
  112. Emco modifications
  113. South Bend Lathe Tool Grinding Jig
  114. OT: the reason for firewalls and virus scans
  115. huge steam engine
  116. more project pics
  117. pic happy tonite
  118. Looking for an electric motor?
  119. Cedarberg Rotary Phase Converter
  120. Aluminum sheet - standards for flatness?
  121. OT: programming
  122. What to use for Mach 3
  123. V-Twin - RUNS ----- Ran
  124. My First Mill Project
  125. Ot:Amazing F-15 video
  126. A brief brazing job
  127. Making A Chuck.
  128. Do you guys have shops in basement, garage?
  129. Old lathe
  130. Opinions on Lathe strong back?
  131. Thanks For Plans Here Is My New Belt Sander I Am Proud Of The Work
  132. What all could you use this for? (lathe)
  133. Club Magazine
  134. VFD motor quality
  135. OT, Firefox problem
  136. It's Alive!
  137. Dovetail Cutters
  138. Old mineral spirits any different ?
  139. Ever hear of Rust-Stop ?
  140. Anybody else having trouble getting the forum to show the pictures
  141. Follow up on cutting metric threads
  142. Dial gages
  143. Snow Tandem Compound Video
  144. adjusting independent 3 jaw chucks?
  145. Making a Surface Grinder
  146. kurt type vise
  147. Mistory Metal any Ideas what it is?
  148. If your in the area drop by
  149. 3phase bandsaw conversion
  150. How to assay silver
  151. For God sakes
  152. Tapered Cut
  153. Lathe questions
  154. Way OT, Healthy "fried" chicken recipe...
  155. OT: Mr. Fusion it ain't, but it sounds promising...
  156. Final OT Xp question
  157. OT: To the friends of YOD
  158. Mill update: Chip shield and Xylotex heat sinks
  159. Aluminumhttp://bbs.homeshopmachinist.net/images/icons/icon8.gif
  160. Split cotter design?
  161. pix of a couple of guns I made
  162. 6" Atlas carriage shims
  163. Can we say Powdercoat?
  164. ATLAS TH42 Original Lathe Stand Dimensions
  165. Heads-up--not a sales
  166. Is It ATF or PSF ?
  167. Engine House
  168. Westech 2007
  169. Keyway done -- finally!!
  170. Sad Today
  171. OT - Website design software
  172. Another Incentive to Attend NAMES Expo.
  173. Enco free shipping code for April
  174. Southbend Question
  175. Tolerence for Tapers?
  176. Rear tool post for upside down cutoff tool
  177. What am I ? (please don't say bad speller)
  178. What Do I Cut 6-4 Titanium With?
  179. opinions on House of Tools - Force Lathes
  180. my metal worker lathe blew up
  181. more centrifuge pics
  182. Making a light tent for photos
  183. Left Hand Thread Question
  184. Bandsaw blade selection...
  185. you guys
  186. ebay problem
  187. So...you want to buy a Kurt clone huh?
  188. CBN cup wheel source
  189. Looking for new editor of HSM!
  190. got in my new lathe today 10x18
  191. Six Jaw Buck chuck Question Pic
  192. Scrapmetal falling.......
  193. Afraid of tilting the mill head? Hell No!
  194. What could the problem be??
  195. Mcduffie Drive?
  196. sphere suggestions
  197. Threading
  198. Tramming in a mill/drill
  199. OT . Automobile Motor Oil . Whats Best
  200. A toilet engine
  201. I'm off
  202. So...do I REALLY have a gurl helper??
  203. OT: Yet another reason to use Firefox
  204. Question On Darex
  205. I can't get anything done...
  206. A cute lil' lathe..
  207. Tool Gloat
  208. fairly O.T. Shower stall/tile replacement
  209. Adjustable scriber project (pics)
  210. D1-3 & D1-4 mounting studs
  211. Welding Cast Iron
  212. the clutter on top of the headstock
  213. Collet Closers
  214. OT: Why would anybody need a stepper this slow???
  215. 3 phase power
  216. Best Electric Screwdriver?
  217. Tap guides revisited
  218. OT: Where to find replacement home HVAC A-Coil
  219. Shop Storage - How Do You Do It?
  220. Semi OT: NiCad Battery life
  221. Used motor oil for cutting?
  222. Band Saw Frustrations
  223. Shoulders and features when turning at high speed on stainless ?
  224. Winter project picture
  225. ot: razr v3t cellphone
  226. Counter-sink size
  227. Ez Tapper,, Junk Or Skunk?
  228. You know what I hate!!
  229. April Fools anyone?
  230. OT: Ghost of e-mails past?
  231. Tool selection aid (pic)
  232. Work Shop
  233. Mill Table Stops
  234. Harvard University Historical Scientific Instruments
  235. new lathe 10x18 from busy bee
  236. OT Computer troubles
  237. pics of first project on new lathe
  238. OT: a honest man
  239. Using a web cam for measuring
  240. Speed for 1/16" Carbide Ball End Mill?
  241. Powder coated aluminum tubing:
  242. V-Twin Engine Runs - Video
  243. My mind is spinning again. New project is it sane?
  244. External Braking Resistors
  245. One tool - two uses (pics)
  246. OT// Model builders, a must see
  247. digital bevel
  248. wire vs steel???
  249. Another NAMES Expo Teaser.
  250. Got my new vise today
