View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 [85] 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134
  1. Need a poor mans surface plate? Free
  2. Free E.M. holder
  3. O.T. deck alternatives
  4. Shaper part repair options/opinions sought
  5. Opinions sought: what size rotary table for mini-mill?
  6. ANY HSM'er around BOLTON ONTARIO?
  7. Am I becoming senile
  8. The Rest of the Story (Fred ...the big pig)
  9. new tool gloat kind of
  10. Thread Chatter
  11. planer blade setting jig
  12. To Slow?
  13. Making a work gear
  14. Welding Cast irion
  15. OT: Home A/C problems
  16. Guess how much?
  17. New (to me) machines!
  18. Firefox 2.0.0.4 and this forum
  19. Not exactly machining, but some is involved...
  20. Punch Former?
  21. 7x Lathe & Mini Mill Info
  22. NJLS Spring Steam Up
  23. High spot marker ?
  24. Pay or Fun it does matter!
  25. PC (laptop) Help Needed
  26. enco
  27. "Improvers Special" CNC - Lathe upgrade
  28. New Mill Wanted
  29. OT - Bob Warfield - Where has he been
  30. Look at the COOL "C" clamp
  31. Search for Salvage Parts
  32. cnc g-code programs
  33. spot welder
  34. Bridgy M head question
  35. Source For Very Thin Washers Needed
  36. Way OT
  37. And another "Improver's Special"
  38. O/T Recommendations For Digital Camera
  39. ID mystery metal (M-14697-30?)
  40. Winchester lathe ?
  41. OT - Atomic Timepieces
  42. Making a little cnc lathe?
  43. Marking out a 45 on tubing
  44. THE burn on my leg..
  45. RTV Silicone for Mold?
  46. small TOS lathe
  47. New CNC router
  48. My Turn Need Some Feed Back
  49. I salute the "Greatest Generation" .. 6th of June 1944
  50. Shopmaster Drill Lathe Mill
  51. sliding key stock?
  52. Vise mounting fixture
  53. dodge/fenner taper-lock
  54. my list of Good Value at Harbor Freight
  55. More newbie lathe questions.
  56. Chinese tooling
  57. Where does one begin?
  58. Seeking Input on a Business Idea
  59. ID metal by smell?
  60. Speeder Handle
  61. Gear on SB9A crossfeed screw?
  62. Bandsaw brazing help needed
  63. dust extractor problem finally solved
  64. Pictures of finished projects ... I Need More Ideas !!
  65. Photobucket test
  66. Mill teardown
  67. Replacement motor for mill/drill?
  68. Internal Grooves
  69. need help with mill
  70. Grizzly H6091 to H6094 DRO Manual Updates
  71. Help ID this grinder- reworked toolpost...?
  72. Is it possible to buy good quality rubber bands anymore?
  73. OT: joining to ends round polyurethane
  74. Interesting high flow water nozzle.
  75. Fastenal carbide end mills
  76. another fire
  77. Harbor Freight Calipers inside and out
  78. Yet Another Enco Mill/drill Question
  79. Metrologists: is this a valid test?
  80. Sill Got Chatter
  81. hoop stress
  82. Another Project Finished (Pics)
  83. Adirondack Live Steamers June 2007
  84. Help needed machining Damascus
  85. Iron work, phase II
  86. Expanding Foam ?
  87. OT: Riding mower drive trouble
  88. DA Collet Specs
  89. More HP needed? or is there another solution?
  90. o/t small rant
  91. SB Shaper speeds
  92. Machining and the James Webb Telescope
  93. Balancing a HF carbide grinder
  94. I think I'm starting to get the hang of this welder...
  95. Latest project
  96. OT: Any of you motorheads heard of siping?
  97. Recycling chips.
  98. Using a spindexer as a 4th axis?
  99. Beetling mill
  100. OT: Western Engine and Model Show
  101. What Was the Smallest Part You've Made?
  102. OT; I just downloaded Safari
  103. Boring Block
  104. OT Bush Gets Watch Stolen In Albania
  105. Dynapath CNC conversion
  106. Rust in float bowl on lawn tractor
  107. Engine House Museum
  108. evolutionary dead-end bicycle
  109. kinky pickets
  110. Grizzly 4003G and the D1-5 spindle
  111. cast iron handwheels
  112. Where can I find a "Beginner" engine kit to build?
  113. Silver solder HSS?
  114. Shaper toolholder
  115. Risking sounding dumb
  116. The last 4", my new mill
  117. Exhaust pipe temp?
  118. A couple things i have done
  119. To Cut or no cut
  120. ? for John Stevenson
  121. Phase II rotary table "fill with oil" What oil?
  122. Rotary Converters - threads on another BBS
  123. Authors... drawings good as-is?
  124. Bar Height
  125. Need some creative thinking...
  126. OT:Win Vista advice?
  127. Etching
  128. OT deck building
  129. Best mount for gear to shaft on Grinder table
  130. Spatter remover
  131. Grizzly 4003G?
  132. Lathe steady rest - FYI
  133. OT:ISP woes
  134. Digital Camera Woes
  135. Poppin Flame Licker Engine
  136. English mystery car
  137. Gassless tip for Miller welder
  138. Dick Institute
  139. NMTB 40 Tool Holder.
  140. Blind welder needs tools
  141. Boring tool adapter questions
  142. Christine the car returns, time capsule
  143. Welding /Brazing Flux ?
  144. Weekend Sale
  145. Leather belt dressing ?
  146. Chinese Lathes (but not what you think)
  147. Tooling Supplier
  148. John's selling workshop apron's on ebay great buy
  149. o/t monitor problem
  150. Yet another shop wiring question
  151. Rigging a new coolant pump
  152. Hard, durable finish
  153. New Boat Seats
  154. Aluminum putty?
  155. Delta Bandsaw Restoration
  156. What to do--Ebay drill chuck
  157. Tin testing
  158. Tube Bending Instructional Manual?
  159. Irish moped gang
  160. O/T HP Sauce
  161. o/t car ramps
  162. Bearing Question
  163. Motor wierdness on the hoe
  164. Proper Drill Chuck Mounting?
  165. Father's Day shop output
  166. Broach
  167. Scraping
  168. turbine casting mold
  169. bnelt strengthening advice same lathe as mark
  170. Harlan & Wolff marine diesel
  171. Building a PMR #5 verticle steam engine
  172. Shemp
  173. Fastenal carbide endmills - update
  174. Plasma cutter woes
  175. OT: A Visit to the Lane Motor Museum
  176. Gloat, ebay bargain.
  177. Problem with Harbor Freight Rotary Table
  178. OT: CPAP machine blower type?
  179. Ebay Curiosity
  180. OT, plumbing, low water pressure.
  181. Engraving bits
  182. oatmeal machine
  183. engineering experience comes in useful sometimes
  184. I officially HATE Firefox.. Bill's crap is better
  185. batteries
  186. Thin Stainless Machining
  187. 3/4 NPT Weld Stub/
  188. Been VERY busy...big payoff!
  189. OT low volatility materials
  190. Jigs for accuracy, speed and safety
  191. Question for Forrest
  192. Where to buy X feed nut ?
  193. OT calling around the world
  194. Radius cutter
  195. Stolen Georga License Plate - Reward Offered!
  196. Ground Auger
  197. Evan
  198. Bridgeport Nuts
  199. Making Gears
  200. Rewiring Old Meccano Motor
  201. NEW and IMPROVED! The MARK III not so gasless tip cover
  202. Timing gears and belt for the Grizzly 1009 cnc
  203. shaper tool holder
  204. Removing the BP Xfeed nut ...
  205. need (2) ~3"diamter aluminum disks, ~.5" thick
  206. microwave metal casting
  207. ?s for Mklotz about his chuck "spider"
  208. taps and drills
  209. O.T. Shuttle Atlantis and ISS just passed over
  210. OK I`m DUMB but
  211. RECORD VISES revisited
  212. 6BA Screws
  213. Square rod bending challenge
  214. Question for Sir John
  215. Remember the wacky "The Multimachine" tool?
  216. OT- why are kitchen ovens so expensive?
  217. Need some advice
  218. Yee Haw, finally a tool gloat!
  219. Help on ID of Weeden hot air toy
  220. Electromagnetic Chuck Polarity?
  221. Need a new Cutting Oil
  222. Boring Block Bottom
  223. anyone know anything about this or whats your opinion
  224. Is your 4x6 band saw acting a bit sluggish?
  225. I've been busy/update
  226. Free Shipping
  227. brazing sights on guns
  228. tool post grinding
  229. securing part for internal threads
  230. OT- Kohler Genset seperation?
  231. Save your feet
  232. OT: Anyone know much about Ailanthus?
  233. Electrical –powering a 220V DC chuck
  234. (OT) Product Safety Warning: Dollar Store Frying Pans
  235. Handy web site for tooling
  236. 4 1/2" A/O grinding wheel query
  237. Prazi SD300
  238. Shantytown washer
  239. Stainless 304 Material??
  240. OT. (sort of) Engineering Journal
  241. First Steam Engine, Power Question.
  242. some airgun toys i have been making
  243. Concrete or not
  244. Revisit the Enco Insert part off tool.
  245. PNW Rare opportunity
  246. What will work, aluminum or ?
  247. Question for the experts!
  248. Tool quiz: name the mystery tool of the day
  249. 2.25"x4.5UN
  250. Mystery too 2.... a real unknown
