View Full Version : General
- Jet 1340 GHB
- Power Drawbar for My Mill
- How well do the import bandsaws track ?
- Multiple home shops, too many hobbies ?
- machining magnesium
- Automatic Electric Aluminum Can Crusher
- anyone know of a good video of cutting threads
- Is there a VFD installation faq anywhere?
- Google's "Sketchup" modeling program?
- 14" rockwell diagnosis (back gear)
- Hydraulic press
- new business
- 16mm milling arbour conversion ..
- Harbor Freight Cable Hoist?
- Bandsaw damper, revised
- gas works
- stock racks
- Die filer with VFD works as power jewelers saw
- Need a bit of help please (milling)
- Generator Project?
- shop vac
- Scored a new to me lathe off Craigslist.
- Help with CRS warping when milled
- just phoned thrud in canada
- sherline products
- Enco free shipping code for Sept
- Which do you prefer?
- home-built steering project questions
- Jig for Cuttermaster
- Jig for Cuttermaster - more pictures
- anvil stand
- Rockrats garage
- It is Rocket science
- Drill press adapter plate
- Slip gauges
- PM forum down
- FUN, painted to match, pocket bike and ZX11
- G.e.a.r.s.
- Gear material - Planetary reduction
- bass akwards die filer
- Simple errors
- Aint that the way.
- water-sensing intermittents
- Machining plastics information source
- Hex Collet Block
- Lessons Learned Last Week
- Custom Dash Lights
- OT: Design layout software for property development
- optical comparator
- Delta wet sharpener bumpy wheel
- OT: Strange Windows behaviour
- Metric threads on an imperial lathe
- Flood coolant on a Bridgeport
- Quick-change tool post problems--help me please.
- Not Rocket Science (photos)
- New Tool For Shop How To Use
- Mill "transmission"
- OT could use your input on yet another tranny problem
- ethics question.
- the benefits of suicide doors
- Lathe Operator
- Vacuum Pump for Composite Work?
- Yea Enco!!!
- Cut out a fabrication step, plasma cutting tip.
- round vs. square tubing strengths?
- Grinder Guide Isobevel
- OT:Just another day at work
- Trial Baloon
- impulse purchase
- fluxcore wire alloy
- Routers on aluminum
- Free DRO and/or Alignment Tool?
- What mill will work best ?
- gold gold gold
- Heres one for Sir John
- need tips on gas welding stainless
- OT: Monitoring Internet Connection Speed
- can you recommend a good book on tool sharpening
- OT High speed events.
- I need some help from the wise and experienced.
- Polycord belt splicing?
- Used Machine ?????
- Looking for a chart of angle for cutting bevel siding
- DAREX E90 problem of electric scheme.
- Help Identifying Motor Frame?
- You Tube??
- Welding Aluminumn 50 series??
- AMT wood lathe parts?
- bridgeport milling machine problem
- Band saw blade question, Help Please!
- quill drive key
- make big bucks with your drill press
- Bandsaw Question
- Enco Brand Cutters
- lathes on stamps
- VFD on Single Phase Motor?
- Milling machine tooling help!
- OT:Solar power system questions
- Suggestions for purchasing a new lathe
- Titanium source for tube
- Motor guru help
- A Man and his Lathe?
- Suggestions for lubrication in dusty area
- Michael Morgan Bridgeport book?
- Aloris tool holder
- what could this be any ideas
- OT maybe, telescope mirrors.
- Putting 10 lbs. of Tools In a 5 lb. Shop
- On Line Plans??
- CHEAP import tap and die sets
- Problem trying to illustrate a point.
- What i've been up to...
- OT - Seattle Man Gets Two Years for eBay Fraud
- big sale in Scotland coming up
- Oh Yea! Bridgeport w/VFD... Sweet
- What's with Rockwell and 7/16 threads on the drill press?
- Source for high(ish) amp distribution bocks?
- Rubber edge guards - like door edge moulding
- Is there such a thing as crap steel?
- Ascot Show UK
- My first project complete (MLA-17 Diesel)
- Spot Welder Update
- Security System, Building an expensive camera lens, cheap.
- Gear / Belt Lathes
- south bend lathe
- Rigid see snake
- gear box shafts for SB9A
- rose engine
- OT - What're your pryor hobbies?
- Hobart Airforce plasma cutters - anyone use one?
- Cutter grinder question,sort of
- The big drill grinding article.
- John's secret identity
- Starrett micrometer head
- Anyone built their own Mag Drill?
- Need info on stready rest for Standard Modern lathe
- Auction
- How to hold ???? in the lathe
- power hacksaw question.
- Milling Machine Power Feed
- Simple question about diamond hone
- Norman your opinions sought on this
- USS Macon and its Sparrowhawks
- Business progress update
- Digital Machinist
- compact5 belt
- Horizontal mill cutters
- Select machine Tool lathe
- Strange readings with digital micrometer
- OT - Kilo prototype mysteriously loses weight
- MLA Filing Machine Kit
- Exporer vs mozilla firefox
- Source for AB power transistor
- handling a shipload of digital pictures
- TIG interference w/PWM controller
- tool grinder table
- Anyone know stored energy resistance welders?
- A Post Script to"OT Who is/was most famous Machist?
- Air tank source?
- some more pics of my workshop
- OT: Alright boys, here's a chance to make some money!
- What is box turning?
- who's into TIG welding???
- odd units
- O.T. carbon nuetral question?
- Pinging OldTiffie
- Idle back inverter genset project
- Shop air lines what is the best material to use?
- Wandering Tool
- Making a Lathe Drive Cener
- Possible use for ER collets?
- Help with Weird Metric Thread
- compound power feed
- Early Jacobs chuck taper
- good enough little filer for you guys in U S A
- Wow, there IS an aluminum fairy!
- for those with a dry sense of humour
- Seattle Boeing Surplus
- airborne machine shop
- Temporary wheel assemblies and over-center wheels
- OT, It's supposed to be funny....
- opinion on a milling machine
- O/T Polishing Brass
- Mobil Vacsul 18F?
- Sput welder?
- O/T computer question
- I love it when a plan actually works
- What to do with JUNK
- one of the other BBs
- A decent sucker is required.
- Jim Sehr's taper slide cutting tool .
- OT: New video available
- OT: Shop/Barn building configuration
- Salt for bending
- A Really Boring Subject
- wish I had room for this
- Wilton 20" Drill Press is home...
- hole drilling question
- OT----Onan 6.5 Genset Operating Temps?
- Replacing Metering units for 1-shot system
- bicycle puzzle
- Moving a milling machine help!....
- Need idea on oil stain removal
- Why Can't I buy one?
- Parts Washer Solvent revisited
- Source for stepper motors?
- My Side Lever Engine came to live
- Mystery Motor
- Gear Hobbing Machine
- Oliver S-4 Die making machine
- Milling on a Drill Press? Eh, ok...
- OT: Some pictures to remember.
- OT- BLUEPRINT READING in OMAHA
- Knee or Quill I want to hear from you guys
- Putnam Endmills
- Davenport
- Mitutoyo height gauge zeroing
- Turbocharger brakedown
- Drilling Glass
- Lathe milling attachment
- Arrr! Matey. It's Talk Like a Pirate Day
- New project done
- Hi guys!!
- dust collectors
- buying from overseas manufacturer
- Repairing a sight tube holding (essentially) ATF
- Two for one special today
- Electro plating
- Cole Drill
- Etching glass
- OT - Information from Former Life
- Madman, clone this, 3wheeler toy in fabrication
- broken off stud
- Female project
- scattershot device
- Lathe Turning unwanted taper
- OT: Very lucky near miss.....
- Project takes a turn...
- Anybody know what this might be?
- metal finish
- slitting when circular slitting won't fit
- Source of brass for the patient
- Gun with no bullets ..and dumb friend
- Keyless chuck HELP!!
- Latest project: 1/3 Mannlicher rifle
- toolholder handedness
- Precision Mathews Machinery
- Ot: Atv
- Small Diameter Battery (Cell): Not Really OT
- DRO's
vBulletin v3.5.4, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
