- Metric Feeler Gauges
- Scraping Experiments
- Home shot peening
- PES 230 DELTO
- Is this "Dividing Head" any good?
- Time zones
- Walking Beam Engine
- Need suggestions for mill vise for Grizzly mini-twins.
- Centering Work in 4 Jaw Chuck
- T-15 HHS
- How strong is my I beam
- My new building..
- mixing metals
- Brass Magnet
- Columbia: gone, but not forgotten
- Right hand tool left hand cutting?
- Are these new digital measuring devices a gimmick
- Need belt for old tool post grinder.......
- Milling cutter help
- Making a chuck plate "101"
- Homemade surface grinder
- Dry air lines
- naked pictures of thrud..
- Thrud, It's all GOOOODDDD
- spindle stretching
- 3 jaw Buck Chuck
- Stainless Steel info website
- Plugged up Kool Mist unit
- Choice of Steel (Marking Knives)
- Any way to tell if a motor is reversible in absence of a diagram?
- Common Courtesy
- Air line safety
- Mini mills#2
- New mill drill
- Spindle Brake
- Jacobs headstock chuck
- Try to remember...
- Delta DP-350 Variable Speed drillpress
- My Surgery
- Quick Change Tool Posts
- Delicacy of VFD's and three phase motors
- Best way to remove concrete?
- Which Height Guage?
- Help with internal lefthand thread
- Copper Suppliers
- Copyright on spare parts
- experiment report
- A monkey in a diaper
- Bandsaw Coolant
- Coolant
- Shaper tool holder
- Scraping school announcement
- Has anyone bought anything from this ebay store?
- What is meant by billet aluminum
- Fishing Reels & Audrey
- Handling roll of shim stock
- virtual machine shop with videos
- Turret Tools
- Aluminum on steel and galling
- Ragnar's new shaper
- Seiki - XL 2VH vertical mill
- Cast iron
- Dust hazard
- Grinding Jig
- Aluminum Surface Treatment. Chrome?
- Advise on a Lathe Bench
- Engine that runs on hydrogen peroxide
- Repairing Dremel Chuck
- Treadle Lathes
- Pumkin Chunkin
- Drawing software??
- Precious Metal Clay
- Loctite 609
- Fuel rails
- Rookie Mistakes
- Help with centering head problem
- Asiatic Production Methods
- Post holes
- Grinding wheels
- Punch Press ?
- IS IT JUST ME?
- 1.00 donation fund for books?? I finally sent in mine, how about you?? :)
- Cranky
- Friction
- Vulcanized Hard Rubber
- Reading lens for saftey glasses
- Shaper advantages what are they ?
- Has anyone ever seen?
- What cutter bit to use
- What's the most unusual machine in you shop.? Work or home
- metric conversion??????
- Sherline Lathes
- Abbreviations
- Starrett model 98-18 precision level test vial
- Tap Grinding Attachments
- Relief Grinding Fixture
- Looking for Used Drill Press or Stand
- Source for The Amateur's Lathe?
- Dissolving broken tap
- adjust of the ram travel on ammco 7" shaper
- 10" atlas lathe bull gear
- TurboCad, DynaCad
- CNC GANTRY
- Plating
- BIG Surface Plate
- Slitting & Jeweler's saws - what are their uses?
- 1st Time Gunsmith
- 460 V from a 230 V phase converter
- job done beautifully wrong
- Post hole postmortem
- Intoxicating Liquor
- Home shop machinist vs Machinist workshop?
- M2-Al tooling?
- Viceroy Sharpedge
- Hard Anodizing Aluminum
- 12" Craftsman lathe for sale
- Worm rack problem: for your consideration
- Have you used "Techno Weld"
- need a book on Hydraulics
- MSC Lathe Stand for 14x40"
- how small end mills
- Turbo cad 8
- Resplined axles
- surplus equiptment.
- finishing a 4" deep bore .5" dia
- Rookie question #233
- Want to learn Gcode commands?
- Any visual basic programmers here? CNC code
- My mothers near death encounter
- Lufkin Tool Company
- Boring Bar Head
- Cutting a 1" Dia. Surface Hardened Shaft in half??
- Fortal?
- clear aluminum
- Rotary Table Backlash
- How many tools have you given away
- What words of advice do you give to new machinist.
- Fusing metal and glass
- Jet JVM-836 and a VFD??
- A Couple Of Lathe Tips, Any Others?
- Mid-West Tool Collectors Association
- stress relief
- cotter pins shearing strength
- to our lapidary-ists
- Stainless Steel Foil and Heatreating
- Injection Molding Idea
- Hello everyone Im new and just starting out
- broaching without a machine???
- Parallel port encoder input for homemade DRO
- Subscription to OZ
- Want to post pictures?
- Grizzly CT-918 feed rates
- Wierd and unusual?
- Spider
- "J" Threads - Need Info!
- Infinite gear ratio for leadscrew on lathe
- MACHINING TITANIUM
- Need a US made motor
- Stress computation
- Home made injection press
- modern metallurgy
- Minimum hole size before reaming?
- handsharpening Drill Bits -- HOW??
- Where's Thrud?
- ebay scam ???
- Cutting very hard Stainless Steel sheets
- Aluminum Machining Speeds
- DRO and longitudinal direction ?
- Scraping baby-steps
- Idea for Neil
- Of Mechanics & Machinists
- Eli Whitney
- Smilies
- power file
- new guy safety
- Machinery's Handbook
- welding helmets question
- changing the I.D. and O.D. of common steel washers
- Fuel for the register debate......
- Just bought a shaper...now what?
- On mechanics II
- wheel dressing
- South Bend
- DRO QUILL KIT
- tire changer lubricant?
- Cat 40 taper
- Wheelchairs in the shop.
- Anyone have experience with Miracle Truss buildings?
- sheldon lathe
- threaded spindle, i want to put L-0 taper chuck on
- Grinding Wheel Recommendations
- South Bend Model CLC 1377
- lathe tailstock drilling
- Large diameter boring
- C40 / C45 -- what is it?
- bridgeport 3PH -> 1PH conversion
- turret lathe
- NEW ENGINEERING MACHINISTS POCKETBOOK
- beginner-projects
- Biax power scraper for sale on ebay
- morgan straight edge
- Making Acetal parts
- Edge finders and center finders?
- Milling Vise Idea
- Anyone know the specs for Z and ZZ collets?
- Shaper planer set up tools.
- More on shaper tool holder
- cylinder hone
- new /old lathe upgrade should I buy
- Rubber for O-ring
- Reamers
- Cut-resistant kevlar gloves in the shop
- Smithy combo Machines
- threading ?
- HSS what kind?
- FANUC CONTROLLERS
- Chrome plating
- brazing -- carbide to tool ??
- A source for mercury
- Thrud is not well
- Found a rubber press
- Fluteless taps
- Rust Removal
- Depleted Uranium
- Low cost injection molds
- c-2, c-5 carbide what’s the difference?
- Internal acme thread
- Large drills enlarging existing holes
- how were measurements done?
- Spot Welder tips
- This broach is killing me!! Help!!!
- clausing lathe help
- Grizzly Bevel Cutters - 60 degree
- leadscrew accuracy
- Clamp down sets
- Thermal Set Rubber Hose?
- Gear shaping reality
- Lifting Lathe ???
- Spice Girls
- Jet tools
- Red Alert: Need HSM in Calif
- What size Magnet wire?
- Alistair's new lathe
- Boring Bars & Tool Holders
- Used Shapers
- What is scraping? How is it done and what for?
- Vertical mill from old crosslide
- myford threading dial
- Cutting sheet aluminum on tablesaw
