View Full Version : General
- Schmidt Coupling
- just a small touch up needed
- filer/saw???????????????
- New toy
- Homebuilt Line Boring Tool?
- Lead screw gaiters
- HELP...Where to find parts for JET Lathes
- Online source of leather for flat belts?
- clark forklift navy model 1940's
- What CAD software to use
- digital cameras again
- What're your diamond lap preferences?
- US Cord Convention
- Moore & Wright scribing block
- Quick Trick for Sunday Machinists
- backing plate to chuck fit.
- G E A R S
- Federal DTI
- Just bought a rare and unusal lathe,
- How to De-rust tables on Mill/Drill
- Belt Grinder
- Lapping a Tapered Hole
- Repair a damaged motorcycle fork tube.
- Starrett Speed Indicator: how to use
- OT; Battery or charger?
- New Metalworking Group in CNY
- Measuring super accurate lengths?
- Diacro Press Brake Questions
- Starting my new shop for my machines
- My new to me compressor
- Special cutters
- this seems like a good lathe belt service
- woodturners big lathe for those who desire big big bowls
- Craftex
- Cherrying
- Wind Chimes
- HSMs near Branchburg NJ.
- I need info on leather punch design
- CNC machining, JEF files
- HF grinder for $99 which catalog?
- Travel & fine cuts & surface finish: need help
- Metal Shapers "What are they GOOD FOR"
- Dry Ice Blasting
- 1893-1903 Pratt & Whitney Toolroom Lathe Collet Question...and Update.
- Super spacer problem
- what size bore for a 2" bearing?
- OT-Glue for car mirror
- Small Diameter Stones
- Maintenance book Available???
- Any truth in this?
- 1" R8 Collets?
- Drill Press Selection
- Oops I machined it backwards and a nice little rotary tool
- Sort of OT: Labeling Technology
- What is it made of GOLD?
- New electronics Q, but not OT this time
- Need a BPT rotary table part...
- friction stir welding
- Taper shank drill sharpened
- YIPPEE!!!! i actually did some "precision" machining - follow up to 2" bore post
- Techshop might be coming to Seattle
- projects on the lathe today
- Overpressure valve mods
- "Instructables" - not all that "OT" - at all!
- Modern Shop Practice Books
- Tolerances, limits and fits
- Need a 6 Jaw Scroll D1-4 mount chuck
- very OT credit reports
- Determining Chuck Capacity
- OT credit chek
- Mach2 users?
- OT - Plumbing advice needed
- aluminum-topped welding table?
- My Mills calling out my name
- OT - Larcenous Seagull
- How to cut minature tubing?
- In the dog house again........
- Unimat on the SB or My "New" Tool Post Grinder
- Small engine repair: precision machining
- Fit and Finish Yes the book is the way
- Import Chucks Some are OK
- Need some tech. info on this one.
- Carbide inserts for dummies
- Milling By Stan Bray (book)
- Import spot welders... and remote jaws?
- OT Need suggestion for a new printer
- It followed me home
- Lube for Dividing Head
- A military salute artical.
- Headstock oil
- Was watching a video............
- data transfer medium
- Welders for SMALL Items
- OT? Source for Mid Priced Visor
- Single, double, triple, quad flute's
- 1893-1903 Pratt & Whitney Toolroom Lathe Pictures
- What a deal! What a waste...
- Need shop recommendation to rebuild lathe
- Any Hazards Machining 41L40 (or Other Lead Alloys)?
- "Secret code"
- Mini atilt
- stupid question about taps
- 9" South Bend Lathe for sale
- Help needed on slip-fit dimensions
- 4 Jaw Chuck Disassembly Question
- Thought some of my Limey friends might find this interesting.
- Does O.T. mean on topic or off topic?
- lathe chuck scroll lock jaw type?
- Best of British
- Cutting to tenths in Z on a Bpt
- image noise reduction
- Corrosion in an aluminum tank
- O.T. LED motorcycle lighting
- A "whysit", not a "whatsit"
- how big is your mill
- Metric hydraulic fittings ?
- OT Computer Question?
- Fixing stripped threads in aluminum
- Ex-Cell-O Mill
- Ahhh NUTS!!!
- hardened shafts vs. wear questions
- Lathe: Internal Surface finish
- something for free to who wants it
- What brand lathe is this?
- What would you do with this?
- I'm baaaack!
- OT - Modern Britain?
- Ed Crankshaft
- kinematics software
- HSM Snow engine
- Vertex brand rotary table... anyone know anything about it?
- 88 viewing
- DOM tubing supplier
- welding rod oven?
- Bolting down a lathe
- Annular cutters on a drill press???
- Shimming a tailstock
- Oiling interval for babbit bearings?
- Clean-up after turning cast metal?
- OT-Replacing a watch battery....
- Unicycle Stephenson's Rocket
- very off topic
- Precision machining, small...
- I can't understand this design can you guys???
- Latest Machining Project
- Lathe leveling and vibration...??
- attempted some threading today and learned a few things
- Made a Rockwell taper holder for id collets
- Lifting a milling machine over the house....
- comp. wont recognize camera anymore
- A fun "production" run this week
- Quick Trip to Cincinnati: Any Machining Stops?
- aligning the headstock on a little Compact5 cnc.
- copper sheeting ????????
- 9x20 or 8x16 Lathe - Ways drawing?
- OT, that's Off Topic for the dummys
- Introduction from a newby.
- Seeking "more light"
- Uses for a 2 Ton Mechanical Punch Press
- It's good to have a machine shop...
- OT/ Raising water pressure on a jet pump.
- Having a day off!
- Thread mike
- latest projects - i finally put it into a web page
- Dividing Head or H/V Rotary Table ?
- Built a sander, lots of pics
- Heads up UK Model Engineering show
- OT: Is it just hopeful thinking or is
- "New-Lube" coolant system, help with ?
- secrets of the sword
- OT OpTics
- DRO problem need help.
- New lathe!
- Theory of Sharpening
- Saw Coolant
- ViaCAD info needed.
- Cement mixing puzzle
- Whats a Dorian BXA and holders worth to sell?
- Introduction
- Free 2D CAD
- Hardinge Horizontal Mill
- Building a bench for Logan 200
- Noise---Gear head vs Belt drive?
- Candle Taper
- Fixing quill slop in Rockwell 17-600 drill press?
- diametral pitch threads on lathe
- Japanese swords on NOVA
- Milling maching table removal process..??
- Thread by Hand
- Endmill "squealing" in corners.
- Can you Recommend books please
- Alternative dial markings
- Machine tool work light...
- Where all the holes com from
- using a 110 v wall wart on 220 v
- Why can't I find a 3" boring head adapter in MT3 drawbar?
- OT - email footers
- Download programs
- Need Link to the Japanese man's site..
- Jacobs Taper Adapter?
- With my dividing head is this possible
- Why Bother
- Rusty steel....
- 1 1/2" - 8 Thd Steel Collars
- Centering toolbit w/rocker style toolpost
- Shim material?
- Soldering?????
- Sorry laddies, OT again digital cameras
- glued bimetallic strip
- Workshop Music
- Ceramic sharpening
- G3616 and G6760 owners/users
- OT: Aircraft identification
- Guess where I will be tomorrow...
- Index Plates For A Sherline Rotary Table
- Foam Cutter; light dimmer controlled battery charger???
- What Sherline Accessories To Buy And When?
- What is the best Tap & Die Set
- Up In Smoke!
- Bought a new plasma cutter today!
- Drill press....what do you think?
- Holy.....
- pinging gopher
- Smithy Granite 1324 ( New Style DRO )
- Fascinating mechanical devices in a movie
- Welded Stainless Steel
- OT Distance Finder
- Schaublin arbor info needed
- Belated gloat (sorta) - new box
- question about ceramic sharpening
- steam shovels
- Thread size for QCTP
- Tailstock problems
- sorce for hobby type hardware
- OT time to close the shop
- To Go Large Or Not?
- Mist coolant??
- Pirates last week, Halloween next week. Whats next?
- Tools
- OT digital rebel xt
- Ball in ball in cube
- How do watchmakers SEE their work?
- Old Iron on Chicago's Craigslist
- How booty rigged would this idea be?
- In it's natural habitat
- Security windows, doors, DOG DOOR?
- Lube for steady rest?
- How to specify a taper
- Beginner books?
- Need Boring Bar Holders for Clausing 5900
