View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 [91] 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133
  1. Need Boring Bar Holders for Clausing 5900
  2. Parkson Gear Tester? - John Stevenson?
  3. Pratt & Whitney drill press restored
  4. harp guitars
  5. Milling machine spindle runout..??
  6. Scraping tools, peering into the future
  7. Milling Machine
  8. OT What copper to use for propane furnace?
  9. Time for a few changes
  10. we need longer & more descriptive titles
  11. This is the way NOT to do things!
  12. MT 2 How good is good?
  13. Making an arbor for gear blanks....question, ideas
  14. These darn dogs!
  15. The mother of all fluid/elastomer compatibility charts
  16. Old home built
  17. Six Flutes on a Bridgeport/RF45 mill?
  18. Another 'It Follwed me Home' and a hydraulics question
  19. Dial dro's
  20. Need Oiler Application Info on Enco Mill/Drill
  21. Maintenance on the Fray
  22. First Milling project.....need some help!
  23. Dial or Vernier calipers?
  24. Gear Hobbing Machine Questions
  25. BBQ covers as machine covers.
  26. OT: Was anyone here into paintball in it's early days?
  27. aluminum foam
  28. Is a Shaper the right tool for the job?
  29. Source for Cast Iron Sleeves -Small Engine-
  30. Great Experience
  31. YZ plane arc; Where does the K go??
  32. ? about Taper cutting
  33. Monarch Lathe value?
  34. Jigs & Fixtures
  35. First Project on my Mill
  36. Does it work? You bet!
  37. Books on Milling Machine Operation.
  38. OT Continuing saga of the propane furnace.
  39. Anybody Else Got An Entry in NASA's "Create the Future" Contest?
  40. OT- Truck Art
  41. Hunting for a shaper
  42. Belt drive compressor?
  43. shaper question
  44. Any HSM in the GTA, Canada?
  45. Involute Gear Profile
  46. Job Interview
  47. Starting out
  48. American Precision Museum Show
  49. Craftsman change gears
  50. Micrometer recommendations?
  51. Free 4 1/2" Type 27 Grinding Wheels 5/8-11 threads
  52. Kind of OT, but not really. Levers and Fulcrums...
  53. Moving to Texas
  54. coolant technique for light cuts
  55. Pinging OldTiffie
  56. Oh, why did - I why did I - why did I ever leave Wyoming?
  57. Is there away to to turn rubber ?
  58. Anyone know of or use Safetap?
  59. Sharp 12x40 electrical problem
  60. Recommendations for a small coolant pump?
  61. Lawn tractor front blade (It's Evans fault!!)
  62. toroidal engine
  63. Sharpening large drill bits
  64. Does anyone know about this brand of lathe?
  65. vector conversion software
  66. South Bend Lathe Pricing ? and premature tool gloat
  67. Gear Cutter Question
  68. Brussel Sprouts
  69. But what did you do today?
  70. Wrasslin' with Mr. XLO
  71. OT: Solidworks ORB Fittings
  72. For rookies only!
  73. I guess I will post a few pics
  74. Big arse MT taper specs?
  75. Craigslist.... Readouts
  76. OT: Trailer Dumper
  77. Ait filtration
  78. Good ways to hold lens filters, adapters and other thin wall rings
  79. Semi-OT: Gave Stick Welding Another Try...
  80. Looking For Model Engine Building Video's
  81. Another old mill in a natural habitat...
  82. Spindle repair question
  83. OT auction in Nebraska
  84. Tool identification
  85. need Acu-rite III DRO manual
  86. OT -again. Vista compatibility
  87. Hardening O-1
  88. More gear cutter stuff
  89. Bronze Bushing Clearance?
  90. 5c to #30nmtb adapter?
  91. My balls
  92. pewter guitar
  93. Very cool CNC art works
  94. 1880 Boynton & Plummer Traversing-Head Shaper
  95. Machining Coolant
  96. Lathe cutters
  97. Import carbide-grinder owners, lend me your rule!
  98. OT Windmills
  99. big shaper in action - folks are always asking to see one
  100. VFD confused, and dumb, gettin dumber
  101. Gear Cutting: Accuracy of Dividing
  102. OT "Astronauts board U.S. space shuttle ahead of launch !"
  103. Some project photos
  104. OT-maze game
  105. Measuring small ID
  106. I'll probably make it through life without......
  107. P M forum is down
  108. O.T. Damn drunken elafants again, raisen more hell...
  109. welding rod oven plans
  110. Flycutter tool bits...??
  111. a piece of history american iron
  112. Need help, installing backing plate on chuck
  113. buying lathe food
  114. OT, XP, XT, and HC
  115. Hacksaw I just bought on ebay
  116. In search of the lost chord....
  117. Old Mill, needs a bath-repaint?? maybe
  118. Elmer's Engine Book on eBay till 10/28
  119. Finally! Been trying to dump this on ebay for years...
  120. I never saw anything like this before makes sense though!
  121. BobCad Help
  122. Resurfacing Cast Iron with MIG Brazed Aluminum Bronze
  123. New lathe chuck
  124. Thinbit grooving, turning tool sweet offer
  125. Boring Head advise needed
  126. Video Spring Making Machine
  127. power hacksaw ques?
  128. GPS educational tele Wired Science
  129. VDF for two motors on a Wells Index 645
  130. My 2nd running engine.
  131. Where to buy D1-4 pins?
  132. Any plans or designs for bench-grinder tool rests?
  133. Is Corian brittle?
  134. Ruger 77-22 Bolt mod
  135. My "New" Old Wells Index Mill Pics
  136. Annular cutter
  137. Variance pitch threads on common bolt and uses of.
  138. Thermostat for infrared heater?
  139. Quillmaster QRA Disassembly?
  140. Using white metal to refurbish a feed nut ??
  141. Upgrading to VFD: questions inside.
  142. Reading diameter of cylinder?
  143. Surface finish problems
  144. Best way to saturate felt for plain bearing??
  145. CNC retrofit handwheels:
  146. VFD hook-up help
  147. Wall woes
  148. OT Looking for Texans Need some Weather
  149. the first leadscrew
  150. Mystery Tool
  151. Fuse-box to VFD question, sorry for being a pita
  152. The dial vs digital question, re-visited
  153. Yet another involute gear cutter question...
  154. Drilling and Reaming Speeds
  155. Tramming a mill...Table vs vise ??
  156. Tailstock turret
  157. INDEX 645, before/after,, pics update
  158. Spelling
  159. Type of ball nut
  160. How to machine an acurate large 3" dia ball
  161. VFD drive hell,,,whats wrong with the manual??
  162. Pneumatic graver
  163. OT: I took some cool pics today
  164. show me your,,,,,,,,,,,,,,VFD,DRO, mill mounting,,,
  165. Leeson
  166. Identifying aluminum stock, milled or ground finish.
  167. Craziest piece of machining youv ever done (or had done) Mitsu VR4
  168. Skimming commutators. What's the secret?
  169. Small Stone Points, Meaning of Groups
  170. Beveling a 30 deg edge with a hand file?
  171. Bin Playing
  172. Making a tap
  173. For those who want a more permanent fix than provided by Viagra and Cialis?
  174. VFD and speeds
  175. Foyle's War
  176. Homemade 4 1/2 inch "Model Makers Lathe"
  177. A mechanical first
  178. Tool-making.... shops are good.
  179. How to ditch a B-17 F
  180. NOT OT! Project pics
  181. X-axis power feed on knee?
  182. Anyone Familiar with this site??
  183. cad for drawing bridges?
  184. XP question.... controlling "focus" change
  185. Shop addition...goes on and on..
  186. HF pipe bender mod
  187. threading, I know you hate it...
  188. grease cups
  189. Drilling a precision hole on a milling machine...??
  190. OT:Firefox browser?
  191. OT: anyone use Cadstar PC layout?
  192. "Wrenching" news...
  193. Holt engine-crankshaft machining-step by step
  194. Any Van Norman gurus here?
  195. Frosting or Scraped?
  196. Silver brazing Stainless Steel Tube
  197. OT -- Shaking Redi-Whip cools it. Why?
  198. To scrap or not to scrap?
  199. Brown and Sharpe staight edge (chrome}
  200. question about gear rack on Jet 1024
  201. Sneak preview on Chinese off the shelf CNC.
  202. Threading counter
  203. Jet 1340
  204. making quick change tool holders
  205. higher mileage at higher elevation
  206. Need Cement finishing advice please!
  207. Pinging wierdscience!
  208. Casting iron
  209. Free CNC software
  210. Record Vice bites dust.
  211. Stents beware!
  212. Seized DRO
  213. What The Heck!!!
  214. motorcycle project complete
  215. Turning a spherical bowl-any tips
  216. what are these for unusual clamps
  217. Future of the HSM
  218. Enterprise lathe
  219. Halloween
  220. Build a tail stock?
  221. OT I started a BB for Old American Iron
  222. Good base milling machine for future CNC retrofit
  223. Drill vs Reamer size
  224. New life for old 4 jaw chuck
  225. OT Camera Security System
  226. OT..but speed/HP cars and jets all the same
  227. Moore & Wright mike
  228. Digital boring bar mount for a Harley cylinder
  229. Need A Simple Test for Titanium.
  230. Perils of using small endmills
  231. Take me to your lathe
  232. The next big thing in motors
  233. Camera accessory
  234. Shorpy.com: 100-year-old photo blog
  235. Circular form tools for threading
  236. machining wanted
  237. Tailstock Woes You may want to read this
  238. hi speed hand grinder
  239. OT: one more go on the propane info please.
  240. Enco free shipping code for Nov and Dec
  241. really cool table saw
  242. ammonia for refridgerant.
  243. New Drill Press?
  244. Parting is such bitter sorrow/Grizzly update
  245. Is milling a morse 3 taper difficult?
  246. Coolant for Grinding
  247. Power Drawbar for the Minimill
  248. Myford 280
  249. Looking for slotting saw arbor design using 1" and .25 keyway
  250. Emco FB-2 Adapter
