View Full Version : General
- Help on miling machine
- Comet boring head
- Adding an engine oil cooler?
- Excel Hardware?
- Atlas timken bearing sources.
- Small project pics
- Snow engine running video
- Estimating Steel Vessel weight?
- Inverted tricycles
- southbend lathe for free
- Reversing a motor
- Most expensive SB 9 I have ever seen.
- OT: Screen savers
- Motor phase vs. surface finish
- I had my eye on this one but it went for big bucks
- OT of sorts: Internet Wireless failure
- hardness of weld?
- Gib Adjustment
- When it rains...it POURS!!!
- Just tool that every home shop needs (video)
- Dunmore High Speed Sensitive Drill Press??
- How does this pedal work?
- Going..Going...Gone...Auctions And The Internet
- could someone make use of this it does not belong to me
- DC motor plus SERVO for lathe question.
- lithium-ion automotive hybrid
- Surface Grinder Accuracy
- Measuring Chamfer Depth
- Can Thermite do this weld?
- Gear cutting video's
- OT/ Any water well guys here?
- Ball turner finished
- OT: Need some advice on software vender
- Christmas time... muahahahaaha
- Angle Grinders - the good ol' topics, revisted...
- Strange End Mill
- ISI DIN 40 tool holder
- My old angle plate
- This long weekends project
- Another revisit...workboots???
- OT using a tv lens on a digital camera
- Guess who ????????
- got completely screwed on ebay
- How does this gear set work?
- Dis-Mount Advice
- Cost to replace spindle bearings on a 11" Standard Modern Lathe?
- 1018-4130 steel
- SINO Resolution
- 'been playing with lasers again...
- Heavy 10 4 sale on PM site
- For the beginner
- Gear repair from Hell!!!
- I can't believe I bought this...
- Willy!!!
- MIG welding safety
- My Metal Treasures - what is it?
- Grizzly 10X22 Lathe - No Collet Closer Available
- New PM forum URL
- What to do? found a SB
- OT/ Computer glich
- rotary convertor from static question again
- Anyone have Enco's free postage code
- PM forum ?????????
- Mill/drills can't and a boring head reminder..
- Tony from Lathes UK...anybody know...
- mechanical exposure calculator
- Idler Pully Bearing for Walker Turner Model 900 Drill Press
- Introduction
- Light Emitting Diodes; Ready for prime time?
- A couple of machining tips
- Another Introduction
- anyone tried to make their own anvil?
- DC motors on Treadmills
- Drilling "long" holes on lathe
- Adhesives (for rubber & leather)
- Blueing during grinding. Affect on Strenght.
- OT How to Search Craigslist
- 4WD rear bar/towbar
- Newbie here, just saying Hi!
- Big fan repair and handwheel pics..
- Fitting drill chuck into tailstock
- CAD Libraries on line tracing parts
- OT slightly as is a car modifaction
- Gov. Model maker job in MD
- Another Adhesive Question
- Calendar for 2008
- For all you military buffs, tankers and steamers
- 3/16" Tangential Toolholder
- silly season
- Tool Gloat !!
- Atlas part ID
- Casting repair
- Bearing Manuals
- Lathe oiler problems and more
- Old Ring Roller pics
- x, y cursor controller
- ** update Calander for 2008 on Lathes add your name
- Mill drill head lifting motor....?
- One of you otta' steal this
- So when you're looking on Ebay...
- Why ballscrews?
- How to machine a cam on a lathe?
- Question for the week left hand pipe threads ????
- MT4 with 1-7/8 x 8 thread stuck on back plate
- Regrind R8 to 30 taper?
- OT: Turns out they were right after all.
- Latest major project nearly complete
- Follow Rest help needed
- A VERY dangerous lil' machine!
- Impressed current cathodic protection in automotive
- optics question
- Knowledge of South Bend 16 Motor Under Lathe
- Couple of cute coupling and motion reversal animations
- Mastercam & Photobucket
- Holding thread wires w/only 2 hands
- Bronze sleeves in a S/B 9" headstock
- hourly $$
- OT - Glass cutter...
- A boy and his lathe...
- Mystery Tool - What is it?
- Slip roller roller question
- Oilite cuttage?
- Question about MW ring roller
- Village Press: Latest Issues
- more spot welder wows
- OT: Tiedown Hook
- Placement of thermocouple in a kiln
- ot: 'deep space frontier website'
- OT maybe: Brown's gas
- Online education
- plans for a grooving insert tool holder
- Enco Code Not Working??
- Trouble with part redux,
- OT: first snow of the season
- Backing for welding
- Rolands article on the CNC lathe
- Price Check Aisle 3 Please
- Voltage conversion on Colchester lathe
- Air assist hydraulic jacks?
- Lubrication
- Touching Up a 3 Jaw
- Parts Washer Questions
- hello
- Metal sliver?
- Line Boring and Welding
- DRO Slides and Carts do not Mix Well!!
- shaper vice
- Making Slide-Out Surface Plate Fixture for Under Workbench.. Advice Please.
- What's Your Preferred Source of Machine Shop Info?
- Z-axis offset devices for CNC
- How to get your article in HSM
- Good Buy ?
- Beginners Mill
- Help with an automotive taper
- Craftex or craptex
- Air compressor woes
- So..you got a gurl working in your shop...
- Unimat does Carbide, see Unimat run, run Unimat, run.
- Steel question, Sir John
- Sieg C6 lathe chuck
- OT/ Small antique bulldozer questions?
- Help from electronic guys (again)
- physics question cmon Evan?
- H/F Carbide Grinder Question
- silicon carbide abrasives source
- Induma mill question..
- plasma cutter
- Don't Be This Guy
- My Xmas Tree (Toolholder)
- What do you do with one of these?
- OT...Too Many Psycos
- Is this site anygood?
- using a giant slitting/cutting blade
- Harbor Freight tool grinder ??
- Boyar Schultz H612 problem
- The sounds of silence: quiet computers
- Snow engine seals again
- Flaming chips
- Magnetic Welding table???????
- Grinder head on a shaper
- Recumbent Bicycle Project
- REAL Canned Air and your camera
- Question for the week Why - flat belts better than V belts and gears
- compensating for a vise when tramming
- HF Band Saw Welder $99
- Socket head cap screw countersinks
- Opinions on the HF Universal Cutter/Grinder
- Bandsaw Blade Size Question
- New Member says hello
- Dividing Head
- Machining stainless steel (304 & 316)
- All ye computer experts...a plea for HELP!!
- Power feed units for Bridgeports
- bead roller
- beryllium copper
- Replacement felt and oil cups for Southbend?
- Missed again
- Care and Feeding of Bridgeport Series 1?
- OT Electrical question
- mystery part
- plating
- Flat Bottom Boring
- Having metal samples analyzed?
- Stuck on a project; need input
- Questions on making a shaft
- London trip - thanks
- ot : 0.3mm and 0.1 mechanical pencils?
- Anybody ever build a page/flyer folder?
- Threading program for r 27 TPI, 19TPI , MM DP and MOD
- the elastica
- Friction and bronze sleeve bearings
- Mill Vice Soft Jaws
- really basic question about bending steel
- Ot christmas lights
- Working harder steel...
- Brake Drum Lathes
- Al Gore convinced me, green, green---green
- Request 4 Help: Bearing design (bike)
- Information about a press
- AXA or BXA Toolpost?
- Slow AC motor
- Tig welder crashes alarm system
- Giant 4 Jaw?
- Coining Press - Base Configuration?
- files for filing machine?
- Twinning air compressors?
- John Gascoyne, RIP
- Load bearing capacity for light structural steel?
- How many carbon credits for vacation in Bali?
- OT:VCR and Tv obsolesence
- all new Camo walking cane
- ?Circuit board? Help/fix
- to climb or not to climb
- OT: New life for old laptop, latest gadget
- Quick Thread Question (Bridgeport)
- Cathead steady
- MIG Welding & reflected light
- Wiring Dual-Voltage Motor for High Voltage
- Help hunting for video
- help with drill chuck
- Very old window latch
- Ot aussies in Sydney
- Holy Crap Pacitor!!!
- X! mill spares in UK
- OT: airco 300 Heliwelder
- Facing Mill for Bridgeport
- OT: Audio Guys – Sound Cards to Surround System
- Simple project from the 30's
- Just A Thanks
- Now you've done it!
vBulletin v3.5.4, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
