View Full Version : Gunsmithing
- Chamber dimensions for 32acp please
- Latest project - Stage 1 - Success
- Time to start the Double Rifle Project, or is it?
- So is this a 18mm pistol
- Loaded pistol mag question
- Integral Suppressed Remington
- "Gunsmithing" steel?????
- shoot distance
- 300 Black out and accuracy.
- Somebody tell me if this is a dumb idea...
- Latest Project
- Two Questions: Rolling Block Actions and Blasting Media
- Savage 29B Part Needed.
- Live ammo on E-Bay now?????
- Need Some Grizzly Lathe Info
- steve acker's lathe
- Got the 300 Black Out back
- Converting a .32 RF to Centerfire. Thoughts?
- Degreasing Before Bluing
- 1873 Winchester Barrel Lining Project is done
- Colt ? black powder flask
- "D" reamer for 22 magnum
- Qu. about modifying H&R .22 cylinder
- Shilen Help Needed
- 303 British Head space
- need info on missing part on the iver johnson hammerless top break 1st model..
- Jeweling Jig
- Threading Help Please!
- rust blue problem
- TV Crap
- stock duplicator question
- 30mm to 1'' scope adapter
- Bob Woods artical Oct/Nov MW
- AR15 barrel ID
- .218 Bee
- Black Powder Cartridge search
- Help selecting rust blue solution
- I've been Busy ;-)
- Anyone flute a barrel?
- what appropriate steel for mauser firing pin
- Need A Bit Of Help
- Lanyard Loop Removal
- Looking for reamers for the 1911 frame
- Need the angle on a Remington 700 bolt handle.
- Tricky relining job - input requested
- Something to cut the slide slot in a 1911 frame
- flintlock springs
- Engraving tools?
- Rifle barrel for .380 acp?
- SS for a rifle barrel?
- Single Shot Rifles Caution, Gun Porn
- Home made chronograph?
- Rusty bluing tank
- Styer prohunter needs a new barrel :( a long and wandering post.....
- Take off barrel ?
- Source for large bore air rifle blanks?
- Scope mount tap
- Pillar Bed question
- Ugly, but it works.
- Not REAL gunsmithing, but as close as I've got.
- Turning Savage Bolt Handle
- Rust blue, what's wrong?
- Handgun accessory rail dimensions?
- Look What I Found in My Scrap Box
- Scope mount on 6.5x55 Swede
- Reproducing Ruger MK II SS finish?
- 10/22 magnum or .17?
- Numrich Discount Code
- Scope Mounting Help
- carnuba wax after bluing?
- Source for 1:9" twist .22lr barrel liners?
- Air Rifle Speed ?
- OT (somewhat) - Trap field shot containment fabric
- .45 Colt .410 compatibility?
- Barrel setup in the mill vise?
- Have a chance to get an air gauge for rifle barrels, need advise
- Drilling old barrel for barrel liner.
- Home made Monopod
- .22 short colt derringer ideas?
- Trigger job helps my shooting score at Appleseed event.
- M1a question
- Lathe Drill
- Blued, FINIALLY!
- What do you use to lift heavy onjects to be worked on your lathe, and setup chuck and
- How small is too small for chambering between centre?
- Rolling block?
- Thanks David Kaiser (38_Cal) Chamber Reamer Chatter solution
- How to install a "Short Stroke" kit on a Winchester
- AR 15 barrel, gun part mfg??
- Carcano Help
- 1891 Argintine Mauser won't eject?
- Modify a 30 carbine to 9mm thoughts?
- Cutting the butt stock on a rifle stock
- Shorten a Barrel
- Great Sig deal!
- Deleted Threads
- Plans for a box lock or top lock breech?
- Chambering a barrel?
- Compensator + barrel length?
- Slight Surface rust
- Single Six Mounting Rail
- Bore Cleaner Substitutes
- D1-4 Cat head now available..
- Hess receiver question
- Starter Air Rifle for nephew
- Finishing a barrel blank questions
- I am thinking about a Derringer.
- Anybody want a COTW?
- For those that shoot Contender frames, check out our new way of making barrels.
- Information on pinning a 10/22 bolt wanted.
- Serial number on Marlin 71DL
- AMT Backup; feeding problems
- Which side of the barrel blank do you junk?
- shotgun barrel
- Single Shot Rifle Build
- Threading a barrel
- 1860 Colt (Pietta) Soft Hammer Face Fix
- grinding 55 degree cutting angle on tool bit.
- Got a few minutes to spare? Gun Porn
- Any avid handgun shooters in here?
- Muzzle Brake Internals
- Older Post Bore cleaner substitutes
- Extended Shotgun Barrel
- DeHass Chicopee Builders - material question
- Machining cleaning Jag?
- Got around to turning the barrel blank.
- .45ACP w/ small pistol primer
- Double rifle lock plans?
- Montana Rifleman barrels
- Welrod Pistol
- AR 15 upper reciver
- 10 mm expander die dimension request
- Bushmaster Carbon 15 barrel nut size
- Parts for Cobray Derringer Mod D.
- Anyone here have a current blue book?
- Specifications for Scope Mounting Blocks
- stuck dart?
- Mounting front sights?
- M224 mortar
- got me thinking
- NRA extended it's $300 Lifetime membership!
- Surface finish on an AR15 80% lower
- Making swaging dies???
- Tek 22
- Plating coming off
- Chicopee RF Action
- 1911A1 Hammer Checkering
