View Full Version : To the HSM genius, thanks
ibewgypsie
02-11-2005, 10:40 PM
I can't remember who it was who said this worked. IT does. A engine hoist converted into a sheetrock lift. Took about a hour or so to cut and weld up the thinwall tubing. I think it works as good as a real lift, but no rental or returns or hurry.
http://img.photobucket.com/albums/v85/ibewgypsie/Dscn0815.jpg
Shoulder is blowed out. Need a shot in it.
All the overhead work makes me feel old.
David
madman
02-11-2005, 10:50 PM
We use a thing called a t bar. Wood nailed like a t that you jam under the drywall. I like yer idea. Drywalling sucks and always will. Anything that makes it easier is cool.
ibewgypsie
02-11-2005, 10:57 PM
Madman:
I am working all alone. I have used the tbar too. Not on this project thou. The worst was working off the 20' aluminum ladder putting up the 12' sections of vinyl siding by myself in gusting wind.
The siding was cold, would break/bust/crack as I tried to cut it below 34 degrees.
David
speedy
02-11-2005, 11:08 PM
most times it is necessary but be careful when working alone Dave, especially up a ladder. Trestles and planks work out faster and safer in the long run. Look after yourself Dave.
Ken
BWS
02-12-2005, 07:54 AM
Redneck tech......works great don't it?
Orrin
02-12-2005, 08:31 AM
Now *that* is one clever idea!
Orrin
ibewgypsie
02-12-2005, 10:39 AM
Someone on the board mentioned it in passing.
I took it to "use" not my ideal thou. I listen, you can learn from everyone. (open ears and mind)
David http://bbs.homeshopmachinist.net//biggrin.gif
02-12-2005, 11:40 PM
Good deal!And heck,if the ceiling is a little low,just keep going http://bbs.homeshopmachinist.net//biggrin.gif
