View Full Version : Cross feed(y axis) power source
02-18-2005, 10:49 AM
I'm looking to add power to the y-axis (cross feed) of a Sherline lathe. This is to face off small delrin plugs(3/8Dia.x1/2llength). It gets tiring cranking in and out for approximately 35,000 plugs. I would like to put a small speed contolled, reversable motor on this axis. Suggestions, welcomed.
This is for a small place that I do part time work for. Right now I'm out of action for a few more weeks. Rotator cuff surgery on my right shoulder. Being right handed it hurts although I'm getting quite adapt with the left hand.
Thanks, guys
Stephen K.
Herb Helbig
02-18-2005, 11:03 AM
Stephen - I'm using a 12 Volt windshield wiper motor that I got from American Science & Surplus for about $20 for the same project on my JET 9x20 lathe. Pulse code modulation speed control and power supplies from M.P. Jones.
02-18-2005, 11:17 AM
Stephen, A small dc motor as mentioned or check out the "Frog CNC" controller from www.avatar.com (http://www.avatar.com) It is programmable and for what you want to do, would become a simple <cut><go><cut><go>...etc. where cut advances at the speed you select, stopping at a point you select. The <go> would return it to your starting point. With the frog you can also cut threads on smaller lathes, with no change gears required, inch or metric possible. I had posted some threading pictures a while back so search for "kermit" on this forum if you'd like to see what it can do.
Geez, I sound like a salesman ... to bad I can't get paid for it http://bbs.homeshopmachinist.net//smile.gif Den
02-18-2005, 11:27 AM
35,000 plugs? Remove the lead screw and make a lever feed. Should work fine for delrin.
