View Full Version : Lathe spindle.. L00?
ibewgypsie
03-12-2005, 11:30 PM
My 1951 Leblond is supposed to be a L00, I have several back plates, one chuck.
The spindle has a female threaded collar on it, chuck has a male w.cone type taper.
How do you tell one from another is there a spec online anywhere? Where I can confirm what I have?
I have been shopping online for a 4jaw chuck. Missed out on one Namebrand w/mount cause I forgot about it. It sold for 99$
David Cofer, Of:
Tunnel Hill, North Georgia
threeboys
03-12-2005, 11:46 PM
Here's a link that might help
http://shopswarf.orcon.net.nz/chuckmt.html
IOWOLF
03-13-2005, 09:17 AM
Dave,I have a delta 14 with L00 the large dia. is 2.75. it is a slick setup once you get used to it, I have a jacobs collet chuck set ,3 and 4 jaw.
Robert Jones
03-13-2005, 12:13 PM
MSC has a Bison 8" 4 jaw with integral mount for about $290 in the L00. It's a little expensive but I have one and it's really good quality, Bobby
ibewgypsie
03-13-2005, 12:25 PM
Thanks..
I'll print out the "lathe specs" page and add it to my documentation. Three: thank you very much..
I am not sure I'll go which way with a chuck. I shop ebay for bargains. It took about 30-some odd tries to get some bargains on Jacobs ball bearing chucks for my lathe tailstock and one for my mill.
I am stubborn, as you might have guessed. The hammer will finally hit the right brand/right one for my machine.
David
threeboys
03-13-2005, 02:42 PM
David,
Here are a couple more that I was trying to find and finally found them.
http://www.workholding.com/BISON-SPINDLE-NOSES-SPECS-L-THD-DIN.htm
http://www.workholding.com/BISON-SPINDLE-NOSES-A-1-A-2-D1-SPECS.htm
They show a couple more of different type mounts if you ever run into them.
IOWOLF
03-13-2005, 04:06 PM
Hey David
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=41946&item=3880997955&rd=1
MidnightShift
03-13-2005, 06:39 PM
Just gotta be careful about those pesky chips inside the L-00 socket...it affects the chuck registration.
I also got the Bison 4-jaw 10" with integral mount...pretty nice setup.
Buckshot
03-14-2005, 05:32 AM
..........I'm at work, info is at home, but I believe Enco has L00 Bison chucks on sale. I reall an 8" 4 jaw was $239 and no shipping wit da code.
Rick
