Mike Burdick
03-18-2005, 01:04 AM
I have this old power hacksaw that I would like to restore. It works fine except the one-way clutch (inside gear – see photo inset) that holds the bow up on the non-cutting stroke is missing some internal parts. I was hoping that someone can identify the manufacturer or that they might have one and can tell me what the missing parts dimensions are.
There aren’t any model numbers on it but the saw’s bow has "TOLEDO" in large letters cast into it. Also, "L W Chuck Toledo Ohio" is cast into the base. It has a lubricant pump that works off a cam during each stroke. The base is used for lubricant storage. The saw weights about 350 lbs and uses a 14 x 1-1/4 inch blade.
Any help would be appreciated....Mike
http://img.photobucket.com/albums/v157/MikeBurdick/Power_Hacksaw_comp.jpg
_____________________________
[This message has been edited by Mike Burdick (edited 03-18-2005).]
