View Full Version : I need a 32mm hex bit socket
n653ds
03-18-2005, 09:44 AM
I need a 32mm hex bit socket, 3/4" ot 1" drive. MSC - nadda, McMaster Carr - nadda, our tool supply house - nadda. Anyone have any idea where to look?
Thanks,
precisionworks
03-18-2005, 10:12 AM
Try these sources:
http://www.mytoolstore.com/ozat/1hex1pc.html
http://www.menintools.com/gp7.html
Barry Milton
chkz
03-18-2005, 02:28 PM
in a pinch maybe you can double-nut a bolt and use a socket or wrench.....not sure if you're just "jammed up" there with a one-off or NEED the proper tool....good luck
Chris
zl1byz
03-18-2005, 02:31 PM
If when you find a source it is worth more to purchase than it is to you. Consider if you have the time, ability and already have 3/4 or 1" sockets. Make up a peice of hex out of some good steel and just use a 32mm socket to drive it. http://bbs.homeshopmachinist.net//smile.gif
John.
