I am trying to make a hub adaptor for a Porsche steering wheel but I need to cut internal splines to match the steering column shaft. I do not have a shaper but I do have a Lathe and mill anyway to do this without a shaper? Thanks!
How do I cut splines?
...with a lot of patience, maybe.
You can grind a toolbit, put it in the lathe toopost, and manually plane out the splines by racking the carriage back and forth. You'll need some way of indexing (and locking) the lathe spindle to index the splines. The toolbit will need to be quite thin, as you can't get a lot of force behind it, so you'll need to shape the splines in stages.
The same thing can be done on the milling machine by putting a suitably-ground toolbit in the spindle, locking the spindle, and planing out the splines by using the quill downfeed. Same caveat about a very thin toolbit, as you can't get much force behind it (although probably more than with the lathe carriage idea). Indexing would probably be easier, as you could put the hub on a rotary table to index it.
Either of these methods would take a REALLY long time, but it is do-able with sufficient patience.
How about this crazy idea? I was thinking of making a small cutting wheel to the shape needed and mounting it on a long rod with a small belt drive mounted in the lathe tool post. The using the lathe head to index I could insert the spinning cutter and take small cuts until the desired depth? This sound to out there? maybe i should draw up my idea and post it?
Hey, it might be made to work. How big a hole do you have?
Rigidity may be a problem.
[This message has been edited by SGW (edited 04-08-2005).]----------
"I was thinking of making a small cutting wheel to the shape needed and mounting it on a long rod with a small belt drive mounted in the lathe tool post. The using the lathe head to index I could insert the spinning cutter and take small cuts until the desired depth? This sound to out there? maybe i should draw up my idea and post it? "
Yeah, that'd work great......except the splined steering columns I'm familiar with are pretty small diameter. If you're into micro tool making go for it.
Randy, taka look at the tool on the following web site http://homepage3.nifty.com/amigos/sl...ing_tool-e.htm
something like it might do what you want.
Mel
[This message has been edited by lugnut (edited 04-08-2005).]_____________________________________________
Oregon Coast
