View Full Version : flux for low temp silver solder
quasi
04-20-2005, 11:41 AM
can anyone recomend a flux for low temp silver solder?
Forrest Addy
04-20-2005, 11:57 AM
By low temp silver solder do you mean silver bearing lead or tin based solder melting about 400 to 500 degrees? If so use any commercial solder flux. I prefer to use "No-Korrode" flux because it stays where you want it.
If you're looking for especially clean joints then use a zinc cloride acid flux but clean it up thoroughly afterwards and neutralize the acid.
As with any soldering operation work with clean bright bare metal.
[This message has been edited by Forrest Addy (edited 04-20-2005).]
precisionworks
04-20-2005, 02:37 PM
Brownells Inc sell low temp silver solder & matching flux. Works Great!
http://www.brownells.com/aspx/NS/store/ProductDetail.aspx?p=709&title=HI-FORCE+44?%20SOLDER
Barry Milton
quasi
04-21-2005, 05:51 PM
Yes Forrest, thats the stuff. I have a problem with the flux turning black like its turning to carbon before the work is hot enough to melt the solder. I have tried a couple of fluxes, maybe I will try some more. By the way Forrest, I find your writing in H.S.M. very informative. I am not a rookie in the maching area but I never fail to learn new things from your articles.
Brownells used to sell a flux called blitz, I think. It worked pretty well but they don't seem to sell it anymore and won't ship any flux they do sell,to Canada.
