View Full Version : HELP with key slots on shafts.
IOWOLF
04-28-2005, 01:14 PM
I have The dims. for the sheaves which is moot due to keyway broaches but I need the depth on the shaft.Is there any where on the web where there is a cheat sheet?
BTW I am doing a 3/8 key way in a 1 1/4" and a 1 1/2" shafts.
precisionworks
04-28-2005, 07:56 PM
Keyway depth on the sheave and keyway depth on the shaft should both be half of total key thickness + .010".
Barry Milton
IOWOLF
04-28-2005, 08:10 PM
The machinist handbook disagrees, sorry. Check the other posts.
BillH
04-28-2005, 08:15 PM
IOWOLF, sounds like you already know the answer.
04-28-2005, 08:19 PM
Machinery's deals with that little half moon shaped section that is milled off when making the keyway.It is added to the half thickness of the key.
All I do is crank the knee up until I see the endmill/milling cutter make a flat spot the full width of the cutter.Then I zero the knee and crank up 1/2 the thickness of the key.
Since I use the same method as John S. and others for finding center with the endmill anyway it's a snap.
If you end up with a shaft diameter/key size combination that's not in Machinery's it's pretty much the simplest way to find it.
IOWOLF
04-28-2005, 08:30 PM
BillH, NO, I KNEW HOW NOT TO DO IT THOUGH.
Weird, thanx for confirming thats the one Ill use.
[This message has been edited by IOWOLF (edited 04-28-2005).]
luke 55
04-28-2005, 08:34 PM
Hi you can look to the following site they had a nice little program to calculate keyway
http://www.geocities.com/mklotz.geo/
Luke
IOWOLF
04-28-2005, 08:41 PM
Luke , can you narrow it down a bit?
irnsrgn
04-28-2005, 08:58 PM
keyway squared divided by 4 times shaft size equals chord depth to within .001. (the crown on the shaft is the chord depth)
irnsrgn
[This message has been edited by irnsrgn (edited 04-28-2005).]
