View Full Version : ? on bearings in elec motor
joahmon
04-29-2005, 05:01 PM
Among the specs for a 1/2 HP motor are ball bearings, DE bearing:none, OPE bearing:none.
What the heck are DE and OPE bearings??
Over Torqued
04-29-2005, 05:27 PM
DE is for "Driven End", that's the end with the output shaft.
OPE is for "Opposite Pulley" end, and that's for the other end of the motor.
darryl
04-29-2005, 08:10 PM
So---that motor has no bearings?
CCWKen
04-29-2005, 09:39 PM
<font face="Verdana, Arial" size="2">Originally posted by darryl:
So---that motor has no bearings?</font>
Not "Ball Bearings". It probably uses bushings.
WLW-19958
04-29-2005, 09:49 PM
Hi There,
I think the "correct" term is Sleeve Bearings.
-Blue Chips-
Webb
JPR
04-29-2005, 10:46 PM
It may have bronze bushings, cheap and easy to replace.
precisionworks
04-30-2005, 12:34 AM
Some of the older motors have a bronze bushing spherical bearing on the back side (OPE). These are non-serviceable and non-replaceable, as far as I can tell. You can add a few drops of oil to the felt wick that surrounds the bushing but there is nothing more you can do.
I'll rephrase that -- if you try to do more, like drive out or press out the spherical bearing it will shatter. If you know where replacements can be obtained, let me know.
Barry Milton
joahmon
04-30-2005, 08:48 AM
Thanx 4 the replies.
If you're interested here's the link; scroll down to the bottom.
http://www.marathonelectric.com/motors/partdetail.asp?PARTID=Y360
