View Full Version : End mill sharpening
MMurphy
06-09-2005, 04:46 PM
Picked a a few end mills during a dumpster diving expedition. Unfortunately most of the end mills needed to be in the dumpster. Maybe two or three might be usable as is. Anyway, while looking them over, I decided to try my hand at sharpening the flutes by hand, since they were trashed anyway. Broken flutes, big chips and so on.
I tried one "technique", laying the end mill on a diamond lap and scrubbing it back and forth while rotating the mill. I did a few strokes and then looked at the flutes with a mag. glass and noted that the original angle had been mostly ground away. Tried the mill with my thumb, felt kinda of sharp but not like a real end mill.
Question. Does anybody think the mill will cut? I won't get a chance to try cutting with it till this weekend.
Second question. Has anybody heard of, or invented a way to sharpen end mill flutes by hand with a fixture of some kind?
I have a fixture that allows me some success in sharpening the end of an end mill on a surface grinder. But nothing for the flutes. Someday I hope to find a used cutter grinder and learn how to use it the proper way. Hard to find.
In the meantime let the flames begin!!
Thanks
ibewgypsie
06-09-2005, 05:06 PM
A cnc unimat with dremel tool mounted on carriage.
A digitizing probe to read flutes, angle, store to simple vb program. That is how you'd be cheapest to build a rig to sharpen them.
I have not gotten the unimat yet.
Smtty58
06-09-2005, 06:05 PM
You need to maintain the angles. Rotating it on the stone will leave the cutting edges parallel to the work, hence rubbing instead of cutting.
