View Full Version : Boring Master Cylinders
Dusty
06-16-2005, 11:24 AM
I honed the master cylinder for the truck the other night and there are still some pits. The bore is at the maximum recomended dimension. I hate to toss it out, does anyone have any recomendations for boring and sleeving?
tattoomike68
06-16-2005, 04:13 PM
many guys make a sleave from stainless steel. shoot for at least a .0625 wall sleave, install a cold sleave in a hot Master Cylinder.(be quick).
then you can re-hone it to stock size and it will be good as new.
Arcane
06-16-2005, 07:08 PM
I've bored a master cylinder out and used the inner tube from a shock absorber for a new wear surface. Seemed to work pretty well. Only problem is finding just the right donor shock absorber.
CCWKen
06-16-2005, 08:06 PM
Yep, sleeve 'em. It's done all the time.
