My Bridgeport Series I CNC mill has a problem that keeps recurring. This must be a common problem because I was warned about this very same fuse holder by a Bridgeport technician who had never seen my mill, and when I openned my electronics cabinet I found that someone had drawn an arrow to this fuse holder and marked it "Z-FU14." Sure enough my Z-axis will stop working and I'll find that the solder has melted out of the 10 amp fuse. Often the solder glob will make removing the fuse a problem. I'm getting tired of this, and I'm wondering why only the Z-axis fuse holder? The Z-axis doesn't even get the workout that the other axis's do. Should I be looking for a problem in the spindle?
The bank of fuse holders is made by Weidmuller and is called "Saks 6" and it is mounted on a rail called "TS32"
Boy, they want $21 just for a spare screw-in fuse cap. Anyway, I've cleaned it up and I'll try to find a high-temperature 10amp fuse but I don't know why this is a problem fuse holder. I'd like to replace it with a breaker.
