View Full Version : Centercutting, non-centercutting endmills?
Pat Miles
06-26-2005, 05:46 PM
Would any of you learned folks care to explain to me what the difference and uses of a centercutting and non- centercutting endmill would be?
Thanks,
Pat
Allan Waterfall
06-26-2005, 06:08 PM
This was well discussed about a week ago,
http://bbs.homeshopmachinist.net//Forum1/HTML/012329.html
Allan
jburstein
06-26-2005, 06:09 PM
A centercutting mill is configured such that it can be plunged straight into the work because it can cut with its center. A non-centercutting mill typically has a little hole in the center which where it was held by a center during the grinding process, and thus can't be plunged into the work.
Typically two flute endmills are centercutting, endmills with more (3 flute, 4 flute etc) may or may not be centercutting, you have to check the bottom and see.
I'll see if I can dig up a picture or two that people have posted in the past to show the difference.
-Justin
John Stevenson
06-26-2005, 06:11 PM
Pat,
Read these two posts.
http://bbs.homeshopmachinist.net//Forum1/HTML/008268.html
and
http://bbs.homeshopmachinist.net//Forum1/HTML/001525.html
Pat Miles
06-26-2005, 06:48 PM
Thanks to the folks who replied! I understand the differences and uses now.
