View Full Version : Aluminum solder
Martin
09-25-2002, 10:58 PM
I have seen demos at car/bike shows where a guy solders with an aluminum alloy and just uses low heat. Benzomatic or cigarette lighter flame.
I was not interested in it at the time so I did not pay much attention to it.
Has anyone ever came across this and does anyone have any info on it ?
Thanks.
Martin
Rotate
09-25-2002, 11:05 PM
There are at least half a dozen vendors selling this magical rod which will solder aluminum at low temperature. I've used ones from two different suppliers and besides being relatively expensive (about $2-3 per 12" rod), it's prone to producing cold solder joints. It may be good for filling in cracks and holes, but for anything even remotely structural I would not recommend it.
If it wasn't so expensive, it may actually make a good low temperature casting material.
Albert
[This message has been edited by Rotate (edited 09-25-2002).]
SGW
09-26-2002, 07:42 AM
I split a package with a friend, years ago. Very seldom use it. It does work, sorta. I don't have a lot of experience using it, but I think if you follow the directions closely re: cleaning and scratching through the surface oxide to get a good bond, you can get decent joints. Like Rotate though, I'm not sure how much I'd trust it for serious structural work.
Martin
09-26-2002, 08:18 AM
Thanks.
I was going to use it for structural work. But, not now.
Guess I'll go back to Heliarc.
Martin
Thrud
09-27-2002, 03:15 PM
Martin:
Any Lead free solder will work - or is it Antimony free? It is one of the two. If you life depends on it it may come in handy, other wise - forget it, it still does a poor job.
