View Full Version : Asbestos gasket replacement
jaywward
09-27-2002, 05:33 PM
I'm finally getting around to finishing up a Stirling engine fan called the Moryia. The prints I have call for a thick asbestos gasket between the hot cap and the cold cap. Can anyone suggest a good source for an alternative material?
If seen reference made to Fiberfrax but am having difficulty locating a source for small amounts. TIA, Jay
yf
09-27-2002, 06:23 PM
check out high pressure gasket material at your local plumbing supply.
tonydacrow
09-27-2002, 06:43 PM
How about some compressed fiberglass? Might that work?
Ozarks Hermit
09-28-2002, 09:13 AM
Jay:
The material I used is called "Mr Gasket".
It is a high-performance gasket material available at some auto supplies, or from a hi-performance race car parts supplier. It looks like thick cardboard, and is the same stuff Jerry Howell sells in some of his kits.
SGW
09-28-2002, 09:36 AM
Try the Small Parts catalog http://www.smallparts.com/
Also McMaster-Carr http://www.mcmaster.com/
