View Full Version : Milling Machines, Horizontal Vs Vertical
Oilcanlarry33
05-26-2002, 09:35 PM
Hi Folks,
Been looking around for a decent miller. Finding lots of horizontals and verticals, but not much in the universal that I can afford. If you had to choose, would you go for a horizontal or vertical and why? I'm aiming for eventually making model hit and miss engines from casting kits. Any advice appreciated.
Oilcan
PS Any particular models or features you'd require?
Rotate
05-26-2002, 09:43 PM
Go for the vertical. It's much more versatile, and if you really need to do horizontal type of milling or slotting, then you can get an attachment which will allow you to do that.
Albert
SGW
05-27-2002, 06:28 AM
Vertical, definitely. Being able to X-Y position to drill and bore holes is extremely useful. Sometimes I wish I had a small horizontal mill as well, but not enough to go buy one.
If you can fit it in, go for a good used Bridgeport. There are a gazillion around, the prices are generally pretty resonable, and it's true "industrial quality."
For a smaller, new machine, take a look at the Jet JVM-626.
halfnut
05-27-2002, 07:24 AM
The main thing that makes a vertical turret mill so handy and versatile is the sensitive quill. As in a handle like a drill press, this makes power tapping, reaming and such easy to do.
One can do almost everything else with a horizontal machine, but they lack that sensitive quill. Also for production jobs the horizontals can be more productive with multiple cutter set ups like straddle cutters and such.
For everyday work a Bridgeport of clone can't be beat. Some of the clones are good, I've got a Roundtower made by Yung Fu, good machine.
I was thinking the other day that if a fellow had a mill drill and a shaper, not much that couldn't be done with the pair. But a Bridgeport is much handier.
LTC Steve
05-27-2002, 08:01 AM
What you want is a small vertical turret mill, also known as a Bridgeport type. With what you are making you will be drilling,boring, milling, flycutting, ect. Horizontal attachments also available.
Universal mills where I come from are horizontal mills with a swiveling table. In a tool and die shop they have specific valuable functions. In a home shop in my opinion their use would be limited. With what you are making you may not even use the thing. Vertical all the way.
Good Luck, Steve
w
MikeHenry
05-27-2002, 10:43 AM
If you have the space go for one of each.
I have a Clausing 8520 vertical knee mill that is perfect for my needs and bought a Clausing 8540 horizontal mill a while back. The 8540 is not yet operational and making it so is pretty low on the priority list as the vertical mill is best for my present jobs. They are both 1,000 lbs or less and can be pretty easily disassembled and moved to a basement shop.
Mike, near Chicago
Peter S
05-27-2002, 05:28 PM
Oil can,
I would go for the vertical, there is no comparison for the sort of work you are talking about. A right angle attachment on the quill may come in handy now and again.
I agree with LTC Steve, A "Universal" mill is not a combination of horizontal and vertical. It is a milling machine where the table is supported by a housing which swivels on top of the table, in a horizontal plane. This allows the milling of helices, eg milling flutes in drills, helical gears etc.
You can get a milling machine with both horizontal and vertical spindles which is not universal.
I don't want to offend anyone, but I would recommend a 2nd hand Bridgeport-size over a new smaller Mill/drill. Of course you need more room, and there may be problems if you don't have 3 phase power, but they are much better. Try and get as many "extras" thrown in as possible, eg vice and collets can be expensive for good quality.
sandman2234
07-02-2005, 10:30 AM
I have a universal milling machine, with both spindles, and the table doesn't swivel. However it does have a vertical table, with a horizontal table that bolts to it. (Figure that one out in your head)
Really a nice machine, outwork a BP any day, any way.
David from jax
(Yes I have a 2J BP to compare it to, and it is a Maho 600P)
gunsmith
07-02-2005, 05:41 PM
I have a universal, vertical horizontal machine. With this there is such a variety of work that can be done. I have only every used the universal table capacity once to do helical work. That universal feature would probably not be necessary unless you would like to get into some very ornate, decorative or die making work. My machine is a Dalih which resembles the Cincinnati machines but much more accurate and user friendly (my opinion). I would suggest the horizontal machine with the vertical head would be the best choice.
jkilroy
07-02-2005, 07:45 PM
If you want a neat machine, find a sturdy horizontal, which is usually not hard to do cheap. They adapt a vertical head to the overarm. This was done a great deal in the past, Kearney Trecker had a stock piece to do this. That way you get best of both worlds, except for the ram extension of the Bridgeport clone. Also, most horizontals of any size come with powerfeed on all the axis, which is a plus. A Van Norman with an adapted Bridgeport head is a fantastic machine, able to do more than either machine could alone. Of course, if you have the space, having one of each is the way to go. http://bbs.homeshopmachinist.net//wink.gif
ztarum
07-02-2005, 09:59 PM
I have a Rockwell Vertical/Horizontal mill available in NJ. More info here:
http://www.practicalmachinist.com/ubb/ultimatebb.php?ubb=get_topic;f=4;t=002363#000000
sauer38h
07-02-2005, 11:20 PM
I'll add my vote about "universal" mill. If you ask for one of those you'll get a mill with an extra table axis (rotation). I don't see combined horizontal / vertical mills often. When I do they seem to be called, somewhat mysteriously, "horizontal / vertical mills".
Some mills can be arranged as either horizontal or vertical mills, though not both at once. The old benchtop Bench-Master comes to mind. Kearney & Trecker made some horizontals with big vertical heads powered off the horizontal spindle. Hardinge made a similar attachment for their UM and TM horizontals, although those mills are more often seen with a conventional Bridgeport M head fitted (or the H head, a Bridgeport head sold by Hardinge).
Horizontals equipped with vertical heads don't have the pivot axis around the column - the feature Bridgeport named their "turret" mills for when they were introduced in the late 1930s.
Stanko
07-03-2005, 02:43 AM
This is a horizontal and vertical mill.
http://img.photobucket.com/albums/1003/cowboy/Dsc01647.jpg
Its Russian from Stankoimport. Has 2 motors and 2 12 speed gearboxes , power feed on all axis. Not your everyday find.
No you dont screw it to the wall the picture is rotated 90°
tattoomike68
07-03-2005, 03:01 AM
here see the picture the right way, whats up with that? silly?
http://img.photobucket.com/albums/v488/miketattoo68/mill.jpg
Timleech
07-03-2005, 03:04 AM
<font face="Verdana, Arial" size="2">Originally posted by sauer38h:
Horizontals equipped with vertical heads don't have the pivot axis around the column - the feature Bridgeport named their "turret" mills for when they were introduced in the late 1930s.</font>
Mine does http://bbs.homeshopmachinist.net//wink.gif
http://web.onetel.com/~duttondock/Index/ListerJP/Flywheelgear-1b.jpg
through to
http://web.onetel.com/~duttondock/Index/ListerJP/Flywheelgear-6b.jpg
http://web.onetel.com/~duttondock/Index/ListerJP/Lister%20JP%20electric%20start.htm
explains what is going on.
The mill is an Elliott O2 universal Omnimil, it's based on the Elliott/Victoria U2 horizontal mill, which was once very common in the UK and elsewhere, & it has a turret head fitted. One end of the turret ram carries the self-powered vertical head, the other end acts as the overarm for horizontal arbor support. mine's from the late 1960's. It *is* a universal mill, with swivelling table.
Tim
Alistair Hosie
07-03-2005, 04:51 AM
here is my little Fritz Werner 16 speed universal mill.Alistair
http://img.photobucket.com/albums/0903/tybachdai/Fritz%20Werner%20Milling%20machine/173db0a9.jpg
http://img.photobucket.com/albums/0903/tybachdai/Fritz%20Werner%20Milling%20machine/dbb52480.jpg
http://img.photobucket.com/albums/0903/tybachdai/Fritz%20Werner%20Milling%20machine/d19fcbbe.jpg
sauer38h
07-03-2005, 01:41 PM
It seems that more verbosity is in order.
My rash words "horizontals equipped with vertical heads don't have the pivot axis around the column" are not so rash but not sufficiently specific. The Bridgeport heads were originally meant to be attached via a suitable adapter to the overarms of conventional horizontal mills. Such mills don't have turrets, as the overarm is aligned parallel to the cutter axis in normal use, so there's no provision for changing the angle of the overarm. When BP started making complete mills, they added the turret rotation axis, as there was no need to keep the front of the head aligned with a non-existent horizontal cutter axis. The turret (and of course the lack of a horizontal spindle) is what distinguished early Bridgeports from conventioal horizontal mills with vertical Bridgeport-type heads tacked on.
Some common vertical mills are laid out much like conventional horizontals, without a turret - the Johansson/Clausing vertical, Bench-Master, and Rockwell vertical are typical (the Rockwell vertical is not to be confused with the similar Rockwell horizontal/vertical - there is a Rockwell horizontal, too). The Stankoimport mill is another good example - no turret.
The Elliott Omnimil is a different sort of beast. Though Elliott made loads of horizontals of a more conventional layout (ie, turretless).
The Fritz Werner horizontal/vertical mill is missing the extra table axis which identifies a "universal" mill, or at least that's what identifies it around these parts. Does it at least say "universal" somewhere on it? Nice mill, in any case.
aboard_epsilon
07-03-2005, 02:23 PM
http://bbs.homeshopmachinist.net//Forum1/HTML/012342.html
my Fritz has universal written on it ....all its lacking is a quill that goes up and down.
that would make it a hell of a machine.
bet theres an accessory head somewhere with this feature on it .
all the best..mark
sandman2234
07-03-2005, 03:40 PM
I am pretty sure my Maho 600P is a universal mill. Doesn't have as many moves as a hoochie dancer, which was how my "Fray All Position Mill" was described, but it is close.
David from jax
John Stevenson
07-03-2005, 04:01 PM
The true term 'universal' is given to a milling machine that has the table mounted on a sub table and it allows the main table to be swung thru an angle in relation to the normal X axis.
The purpose of this movement is to allow the bed to slew to enable spiral milling to be performed.
A bridgeport isn't a universal and from the pictures posted and linked to neither is the Stankomill or Alistair's Fritz Werner.
Marks Fritz Werner is, in fact it's very clear how this works and how it still keeps power feed thu the clutches when slewed.
Tim Leech's mill is also a true universal.
Many of the British mills, Victoria, Elliot, Butler, Ajax etc had the same numbering system but different prefixes to denote whether they were universals or not like U2 etc.
John S.
