View Full Version : Grinder wheel holders - what taper?
Mcgyver
08-05-2005, 09:42 AM
Here are some 1.25 grinding wheel holders. They mount on a taper of some sort, not sure what type of grinder they are from.
Anyone know about grinding arbor taper mounts, ie are they a standard? I'd like to find dimension for the taper so i could make an adapter.
http://i20.photobucket.com/albums/b201/michael0100/mystery%20stuff/grindingwheelmount.jpg
http://i20.photobucket.com/albums/b201/michael0100/mystery%20stuff/grindingwheelmountcloseup.jpg
Steve Stube
08-05-2005, 10:56 AM
You have three samples to measure to ensure they are alike and those numbers will give you what you need to make a spindle for them or look up. I'm not aware of a Standard for grinder spindles but it seems to me that even if there is you will still need to measure what you have to check the fit.
Forrest Addy
08-05-2005, 11:07 AM
You're down to this: make a gage. Measure the gage taper. They look like Cincinnatti T&G hubs. I see some stamped part #'s? Maybe Cincinnatti can be helpful. They do have an excellent customer service organization.
Mcgyver
08-05-2005, 11:30 AM
thanks guys, Forrest that was the sort clue i was looking for and Steve you're right, even with dimensions the taper it would need fitting. I would probably mount the piece in the 4 jaw, indicate with a tenths indicator as best i can, then indicate the taper setting over the compound, cut and check with blue. nevertheless, was curious of their heritage
beckley23
08-05-2005, 09:24 PM
Do a search for Sopko wheel adaptors in the MSC catalog.
Harry
08-05-2005, 11:17 PM
Just look at the Sopko website. Last time I checked, they had domensions on most all of their adaptors shown.
You will have to search a LOT of info, but you will probably find them.
Don't recall the URL, you can just google them.
