View Full Version : Reclaiming machinable wax(?)
Smokedaddy
08-12-2005, 01:51 PM
I'm curious if anyone has direct experience with the reclaiming process of Freeman’s machinable wax from a home shop machinist budget? What is involved in actual cost, the equipment and safety precautions if they exist?
-SD:
Stepside
08-12-2005, 02:39 PM
To reclaim the wax get yourself a crock pot. I use the high temp setting when I am around to watch close. If I have all day I use the low setting and it takes almost 6 hours but you will not burn the wax. Pack the pot as tight as possible with the bigger pieces and melt that first and then ad the shavings a bit at a time. This stuff melts at 315F so don't get it on you---it burns like hell and has a lot of heat to lose so it burns for a long time. It would be like using a hot glue gun on your body.
For a mold I have some frames made of aluminum angle. These frames have no bottom and just sit on a piece of Melamine covered particle board. I ladle it in with a chefs ladle that I have preheated in the wax in the crock pot. Because it shrinks about 3/8 inch per foot it doesnot stick to the Melamine or the aluminum if you let it cool overnight.
Smokedaddy
08-12-2005, 03:33 PM
Setpside ...
Interesting ... thought it was going to be something out of my reach. Is there a "best source" supplier for small quanities or simply use a place like Travers?
Thanks,
-SD:
Stepside
08-12-2005, 07:44 PM
www.freemansupply.com (http://www.freemansupply.com) or their hobbyist site www.hobbycast.net (http://www.hobbycast.net)
They also have some other "toys" that would interest people on this bbs.
Spent time on phone regarding if the wax was toxic in a lost wax situation. I was assured that it was not.
The usual disclaimers as having any financial interests in this company ect.
[This message has been edited by Stepside (edited 08-12-2005).]
