I was wondering what I could do to strengthen this stock differential. Here are the specs:
Code:
Housing Material: High strength die cast aluminum alloy Width: 5 1/2" from side to side, not including axles Height: 4 1/2" from top to bottom, not including sprocket Bevel & pinion gears: High quality, steel cut gears Gear shafts: Stress-proof steel Bearings: Self-lubricating Maximum Torque: Static tested to 500 ft. lbs. Weight: 7 pounds, not including axles Lubricant: Bison Grease #1650 Horsepower Rating: 2 thru 14hp
Any ideas on how I can really beef this up inside? It's going into my next project (PsychoBuggy).
-Adrian
