View Full Version : Do you switch gears all day?
CCWKen
08-19-2005, 09:45 PM
Geez, this week has been dragging. Not by choice, but I've got about 10 projects all going at once. Each one waiting for a part or a tool. I'll get to a point and discover I don't have the part or need to order/make another die-set or something.
I move on the next project and the same occurs. I'm running out of bench and floor space! I can't wait for cooler weather. I can start some body shop projects. Anybody else have to work under these frustrating conditions?
08-19-2005, 09:57 PM
Every single day of my life!I've been running some new air lines in my wood shop,two circuts,dual filter regs,hooking up the bead cabinet and a new hose reel.I have done it one fitting,one pipe,one reducer/elbow/sleeve at a time for the past week.I either can't remember everything I need or something at work pops up and prvents me from being able to round up the parts.
I'm also rebuilding an Oliver 18" planer,this week my old Belsaw craped out and started me thinking of how to fix it.Then it dawned on me,forget the Belsaw till later!It's just going to sidetrack the Oliver.
Work this week went smooth,well until Wendsday when I busted the lathe topslide,that fix cost me 6 hours and screwed up the rest of the week.
CCWKen
08-19-2005, 10:09 PM
Hey "D"! I hope you get that "monster" wood lathe Saturday. That should look real good next to your bench. Or on the bench. Just don't hide it behind a pencil. http://bbs.homeshopmachinist.net//biggrin.gif
snowman
08-19-2005, 10:16 PM
well, lets see...
cnc router needs the ballscrew turned down then it'll be done
need to oil the ways on the van norman
need to finish reassembling the leblond
need to get the new bandsaw pulled in to the shop so i can figure out what size blade it takes to get it running again
need to replace the switch on the table saw and the bandsaws
need to rewire the switch on the lathe
need to take the radial arm saw apart and clean the brushes
need to build a welding table
need to finish the restoration on a 8" jointer that i bougth at a yard sale
need to find the floor in the garage
rewire the lighting so i have flourescent all over the shop instead of can lights
install insulation so heating bill isn't 450 bucks a month this summer
mount my new fan on the wall
there are so so so many more, that i can't even remember. i finish projects about two or three times a week, but when the day is 90 degrees and 100% humidity, it's impossible to work.
this weekend, wedding tomorrow, sunday have to go visit the 'rents so we can discuss wedding plans
then the work week begins again...and i just volunteered to work on a friend's car next week, probably for "favors"
So yes, it's very easy to start a project and have another show up just in time to interrupt, or just need a quick trip to home depot to get wire nuts, a fitting, etc...
-Jacob
3 Phase Lightbulb
08-19-2005, 10:26 PM
I've got pending projects everywhere.. My latest project is prepairing the GSX750 engine and get it onto an engine stand:
http://www.bbssystem.com/buggy/projects1.jpg
http://www.bbssystem.com/buggy/projects2.jpg
[This message has been edited by 3 Phase Lightbulb (edited 08-20-2005).]
CCWKen
08-19-2005, 10:51 PM
Hey Adrian, do you sling and move the motor out of the frame or just muscule it out. I've never pulled an MC engine. There's got to be a better way.
I'm waiting to see pics of your IRS set up! I hope your not going to use SS tubing. It looks pretty but doesn't take kindly to constant flexing.
3 Phase Lightbulb
08-19-2005, 10:56 PM
I'm having a problem getting that engine out.. It looks like I'll have to remove the valve cover which drops the height of the engine another 1-2".. The oil pan drops down inbetween the frame so that makes it hard to get out. I Basically just muscle it out and quickly place it on the ground. I can lift it for a very short period of time.
-Adrian
Michael Az
08-19-2005, 10:58 PM
Well, lets see, had to argue with one customer that my ball joint bolts cost a minimum of $25 each because it can take an hour to make one and I can't work for Chinese wages of three dollars a day. Waiting for some prints to show up for some shear blades. Just getting ready to fire up the surface grinder this morning and a friend calls because he needs help in his shop today. That was the best part of the week though as I ran his 36" G&E shaper. I have to get a shaper!
Michael
CompositeEngr
08-19-2005, 10:59 PM
"install insulation so heating bill isn't 450 bucks a month this summer"
You sure do things different in MI.
08-19-2005, 11:15 PM
<font face="Verdana, Arial" size="2">Originally posted by CCWKen:
</font>
Haha,little do you know that I am planning to corner the market on handcrafted toothpicks http://bbs.homeshopmachinist.net//biggrin.gif http://bbs.homeshopmachinist.net//biggrin.gif
Carl
08-20-2005, 12:50 AM
<font face="Verdana, Arial" size="2">Do you switch gears all day?</font>
Yes, I have a 13 speed in my truck http://bbs.homeshopmachinist.net//biggrin.gif
topct
08-20-2005, 09:00 AM
Hey 3ph, here's how you get that engine out.
Get an old piece of carpet about the size of the bike. Remove the cam cover and oil filter. Lay the bike on it's side. On the carpet. Unbolt the engine and lift the chassis off by rocking it back up on it's wheels. Iv'e done these by myself, but if you want to leave the chassis together a little help might be needed. If you strip everything off it's a breeze.
The factory uses a "C" hook.
Gene
[This message has been edited by topct (edited 08-20-2005).]
torker
08-20-2005, 09:19 AM
topct...Ha...I saw that same trick on one of the Chopper shows the other night. I think it was Arlen Ness did it. Pretty slick!
Ken...Glad you asked this question. VERY frustrating isn't it? Makes a shop grow small in a hurry!
My biggest problem is trying to do big projects while still keeping room in the shop for day to day "walk in" customer orders.
Right now I have five four wheel drive rigs on the go and a Camaro restoration. Then there is all the room I need for the rear diff narrowing jig etc.
I have a smaller brake, a bead roller, a ring roller,tubing bender etc. etc. that are all stored to the side so I can work. Very maddening when you need one in a hurry.
I used to get really angry at it all but really...it didn't do any good http://bbs.homeshopmachinist.net//biggrin.gif
It's my fault for not saying NO!
Russ
3 Phase Lightbulb
08-20-2005, 09:26 AM
Topct,
That's a good idea. I might have a hard time finding enough floor space to lay it down tough http://bbs.homeshopmachinist.net//smile.gif The first GS750 I removed the engine from, I got impatient and just cut the frame right off http://bbs.homeshopmachinist.net//smile.gif You can see the engine on jacks in the back.
http://www.gnuxtools.com/psychokart/dscn1908.jpg
-Adrian
topct
08-20-2005, 10:29 AM
Switching gears?
Today I am going to a ladys house and replace two wall outlets. Try to figure out what the hell the previous homeowner did when they wired some overhead lights. Replace a kitchen sink faucet. And try to figure out why her toilet won't flush.
When I get that done I have to come home and weld a fender bracket on a nieghbors trailer. And make his trailer lights work.
Then I get to repair a microphone snake that got ran over by a lawnmower of all things (only 8 channels).
I hope I can get it done because I have to leave here, drive 40 miles to play some music in our little pretend we're rock stars band.
Gene
3 Phase Lightbulb
08-20-2005, 01:30 PM
I got into a little argument with the engine this morning.. I told her to come out, and she told me to go to hell, so it got ugly and the Harbor Freight portable bandsaw ended the dispute:
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=47840
That saw is amaizing for the price... Cut through the down tubes and upper frame in a few seconds with ease.. Like cutting soft butter.. I've only used that portable saw twice and I've already got my money out of it.. Amaizing.
http://www.bbssystem.com/buggy/motor4.jpg
http://www.bbssystem.com/buggy/motor5.jpg
sandman2234
08-20-2005, 04:58 PM
10 speed in the truck I drive, probably change gears more than Carl, since I only drive in the city, or spotting over at the mill.
David from jax
I have too many projects to list...
John Stevenson
08-20-2005, 06:05 PM
<font face="Verdana, Arial" size="2">Originally posted by 3 Phase Lightbulb:
</font>
You good at welding ?
Weston Bye
08-20-2005, 08:47 PM
Lightbulb: Go easy on the embedded pictures. Some of us Luddites are still using dialup. Takes forever to download. I can hit Stop and interrupt the transfer and usually get the text with a broken picture symbol, but if I want to see the picture I have to wait for what, in this case, turned out to be all 5 of the same bike from various angles and stages of disrepair. Much easier to click on a link to view the pictures I might be interested in.
I suppose it is an opportunity to switch gears, go to the can, or go do something else while an ocean of pictures dribbles in through the little telephone pipe.
Wes
3 Phase Lightbulb
08-20-2005, 08:57 PM
Yup, I weld but I'm tossing the frame anyway. I'm going to cut out the VIN# that's stamped on the frame and weld that onto my buggy so I can legally register my buggy as an ATV with the Conservation and Recreation Dept.
I replaced the pictures with links... The one picture I left was the GS750 engine I used to build my PsychoKart: www.psychokart.com/videos/psychokart.wmv (http://www.psychokart.com/videos/psychokart.wmv)
-Adrian
chkz
08-20-2005, 10:54 PM
Hey Adrian,
Great looking machine! Nice job! What did you use for a transmission?? I havent' been following the story....
Take care,
chris
3 Phase Lightbulb
08-20-2005, 10:59 PM
I use the stock 5-speed tranny. I have a clutch pedal and a floor shifter with linkage down to the tranny. You can click on the small pictures and see larger ones here:
Also, here is a high quality video (24mb). I suggest you right-click, then select "Save-As". Watch the video after it has finished downloading:
www.psychokart.com/videos/psychokart_svcd.mpg (http://www.psychokart.com/videos/psychokart_svcd.mpg)
I have hundreds of pictures so if there is something you want to see in detail just let me know.
-Adrian
Your Old Dog
08-21-2005, 08:58 AM
I needed this thread! Plenty of projects started here as well but my problem is I end up somehow feeling guilty about it all !
I've collected materials needed for several projects but driving 2 hours each day to/from work don't leave much time at end of the day! Retirements just a few years off.
Carl
08-21-2005, 10:50 PM
<font face="Verdana, Arial" size="2">10 speed in the truck I drive, probably change gears more than Carl, since I only drive in the city, or spotting over at the mill.</font>
City and mountain driving with my Kenworth tandem dump truck. I have an old style metal splitter selector knob on the gear shift with the word "SPLITTER" cast into it. My hand has worn the knob down far enough to lose most of the lettering and leave a mirror finish. http://bbs.homeshopmachinist.net//biggrin.gif
[This message has been edited by Carl (edited 08-21-2005).]
madman
08-23-2005, 10:08 AM
You know if you spent way less time on the stupid computer maybe youd get some stuff done.
Your Old Dog
08-24-2005, 08:19 AM
madman, well put, very tactful. You must have given that response all of 2 or 3 seconds before you let it fly.
If it was aimed at me, up yours.
John Stevenson
08-24-2005, 10:18 AM
No it's true what he says and I didn't take that as aimed at anyone.
It's also something I'm coming to realise as I mentioned in the "I'm bored" post.
been giving it some serious thought lately [ in between doing washers http://bbs.homeshopmachinist.net//biggrin.gif ]
John S.
imakechips
08-24-2005, 05:47 PM
When I'm at work, sometimes I do have to swap around all night.
I may be on the mill one minute, the next I may be on the lathe. Fifteen minutes later I may be grinding(surface, ID/OD, or jig). I may have to set something up on a CNC mill or lathe and do a quickie program. I might even have to go out ot the production area and work on a monster stamping press. Some nights I'm able to work on whatever job or jobs I'm assigned without any interruptions, but that's pretty rare.
[This message has been edited by imakechips (edited 08-24-2005).]
