View Full Version : Acu-Rite scales
JPR
09-02-2005, 01:21 PM
Will an older AR-5 Acu-Rite scale work with the current Acu-Rite 200 series displays? I see that they sell and adapter to go the other way, new scale with older displays.
nheng
09-03-2005, 07:38 PM
Looking at the AR5 scale technical data, it shows that the scale has digital outputs, quadrature timing and even has a reference mark, just like the new ones.
Compare the spec sheet against one of the newer ones such as the ENC150's. It may be a simple matter of a new connector pinout or perhaps no change at all. Be sure to compare the supply voltages also.
I have a 200T turning DRO and am using Heidenhain scales on it with no problem. Had to re-terminate the ends in the proper connector and pinout.
Den
nheng
09-03-2005, 07:44 PM
The pinout is the same. They should plug in.
The only other possible issue is the interpolation applied to the quadrature signals (4x, 2x, maybe other). A quick call to Acu-rite tech support should get you an answer. They have always been competent and patient. Den
