View Full Version : OT - Heating with Wood
Too_Many_Tools
09-11-2005, 10:46 AM
Considering the projected high cost of heating this winter and to supply an alternate heat source in case of fuel/electricity loss, I am considering installing supplemental heating fueled by wood.
Since in the past this group has been a fountain of good information, I thought I would ask for your advice.
I would like to hear of your experiences, recommendations for suppliers and suggestions for installation.
Thanks in advance,
TMT
09-11-2005, 11:02 AM
First check with you insurance company.
tattoomike68
09-11-2005, 11:46 AM
"earth stoves" and "blaze king" are common around here , both are fine stoves.
pellet stoves are fine as long as the power stays on , they are very efficient. pellets are nicer for the wife to handle than packing logs. (I used to build & weld up pellet stove prototypes)
I did have a wood stove in the living room and one in the basment , the one in the basment worked good at keeping the floors warm. the one in the living room would almost run you out of the house.
packing in wood was kind of messy, the stove in the basment was nice as I could toss logs through an open window right into the house and not pack in down the stairs.
years back we could buy a logging truck load (14-16 cord)of smaller logs for about $800, not sure what one cost now, but it was cheap.
wood is not much work at all if you have kids who can split and stack, then pack the wood in. lol http://bbs.homeshopmachinist.net//smile.gif
good luck.
Michael Az
09-11-2005, 12:49 PM
About five years ago I bought a Yotul woodstove and have never looked back. Furnace hasn't been lit since. The Yotuls are the only stove manufacture that builds their stoves from the ground up including their own foundry. I did what you are now doing and checked out everything I could before buying. There are several companys that are made in America but their castings can be from anywhere. Anyway, I think my stove was around $1800, maybe more. Be sure to go with porcelan, {spl} you won't regret it.
I heard this week on tv that heating oil would probably be 60% higher this year. I would definately go to wood. Some areas may have restrictions, so you want to check that out.
Michael
Mcgyver
09-11-2005, 12:53 PM
growing we had two wood stoves that went 24/7. there was central heat, but the PU's liked the self sufficiency idea.
we to bought the wood in bulk and it arrived on a logging truck. I can tell you that even with chainsaws and a hydraulic log splitter it is tough work. That equipment lets you process more per hour, but I swear you still burn as many of more calories per hour! Having grown up with the work, I inherited none of their romantic notions of self sufficiency! Then again coming in on a winter day, or coming down on a cold morning and always having a warm stove in the kitchen was special.
the very basics are a supply of dry hardwood, at least 2 seasons, an airtight stove (you want to maximize efficiency, it doesn't really flame, more sort of glows), and most importantly have the chimney installed properly and constantly clean it. This is important – if you should clean your chimney in a fireplace every couple of years and you have 20 - 40 fires, think how often that stovepipe needs to be cleaned with it going 24/7. A chimney fire is the fear of all wood burners. You set your self up to do this yourself and the chimney will have a clean out.
The insulation of the chimney and the pieces that support the chimney as it goes through floors and roofs must be for wood stoves – learn and understand this yourself, its easy for an installer to use the wrong stuff. That’s what happened to us, our house caught fire because the installer used the wrong grade of insulated chimney (almost lost the house – rural fire dept drained the pool with their pumper and that saved it).
If you really want to do big, when my parents built their current abode they installed a wood fired, hot water heat system. The heater (not a boiler, it just heats the fluid) is in a separate out building with underground pipes running into a heat exchanger in the house. The exchanger has an electric furnace back up.
SGW
09-11-2005, 01:43 PM
Back during the last wood heat craze (1977 or so) I heated mostly with wood for a couple of years. As Mcgyver says, it's a lot of work if you do the cutting/splitting yourself, and if you don't you lose a lot of the money-saving advantage of it.
But there is nothing like looking at a woodshed packed solid with 4 cords of wood in October and feeling gloriously independent.
At that time I had a top-loading downdraft stove made by Mohawk Industries. I doubt they're even still in business. It wasn't much to look at, but it worked great.
As far as chimney fires....give the fire enough air to BURN, not smolder. There's a great urge to cut the draft way down, especially at night to prolong the burn time, but resist the temptation and you'll get much less creosote buildup.
Your Old Dog
09-11-2005, 01:45 PM
We popped $3,000 grand for a Lopi Endeavor two years ago and learned a lot along the way. (BTW, the following Summer I got another LOPI for the shop at a yardsale for $50.00 and he helped me load it on my truck!)
1. The size of the stove relates to how long it will burn and "not so much" how much heat comes out of it per hour. So we got stuck with a medium sized when we should have had a larger one. We get 10 - 12 hour burn. The larger one was supposed to be 14 -16 hours.
2. When they talk about efficiency, they mean how pure is the air coming out of the chimney. So our wood burner is one of the highest rated in efficiency. That means that it sends 90% of the heat upstairs into the chimney to insure that the stove burns clean! (there is an advantage in that for you, the chimeney stays very clean)
3. If you buy a "zero clearance" like we did than that means you need to buy the optional $250.00 squirrel cage blower that sounds whimpy if you want any heat from the stove. When my stove is ripping hot, I can lay my hand on the two sides and back. If that were not the case, I wouldn't need the blower. Not an issue until you loose electrical power which was one of the goals of the stove, emergency heat.
4. If you ain't got your wood already you are late. You'll be buying wood that was just dropped and it's btu output will be nill for months. If the wood sounds like bowling pins falling off the truck it will light quickly and burn beautifully. If it thunks when it hits, its wet.
5. Many new stoves don't have chimney dampers (they want all the heat upstairs for "efficieancy"). If your home is out in a cornfield like ours, the winds scream past the house and cause too much draft costing you much heat.
6. Have it professionally installed. It cost me $400 for two extremely well working guys who spent 6 hours on my installation of my 500 pound stove! They did a flawless job and I can boast to the insurance company it was done by professionals to code. At first I thought I'd save the money and do it myself. That would have been a stupid error on my part. I do most of my own chores but glad I passed on that one.
7. If you put it in your living room, you may have to watch TV in the nude. Not that there's anything wrong with that, just a little unorthodox!
8. We have a large pile of wood stacked up in the backyard. I throw it on a small utiliity trailer and move it around to the front porch. I can get about 1/2 cord on the porch. When you bring in the wood the family cats will be buzzing around you looking for little creatures to play with. Thankfully, cats like playing with spiders.
9. We only have to clean our stove out about once per week when using it hard. It's not too messy.
10. Advise getting a stove that is deeper than it is wide. It's easier to fill the stove from the front door if you can just shove'em in lenghwise and not have to put them in width wise. You can also get a full pack using that methode. Otherwise, if you packed the widthwise stove you'd have trouble opening the door. (When we close the glass door, we are looking at the ends of the logs)
11. We got a glass door on ours and we like it a lot. If the stove burns hot it keeps the glass cleaned off about 90 percent. We like the ambiance while we're watching tv in the nude http://bbs.homeshopmachinist.net//biggrin.gif
12. We get by with about 4 cord a year in a 80 year old home with little insulation but it is sealed up pretty tight (no drafts). We burn hard once it gets cold out.
Would we do it again, yea, but with the observations noted above. Good Luck.
[This message has been edited by Your Old Dog (edited 09-11-2005).]
Wayne02
09-11-2005, 08:30 PM
<font face="Verdana, Arial" size="2">Originally posted by Your Old Dog:
</font>
Oh how true this is. I bought and installed a new woodstove in my shop last year. Got the high efficiency, blah, blah, blah model. Works good and is sized just about right for the shop as far as heat output goes.
But what I didn't check was the log size it took. It is very shallow and only takes like a 14-15" long piece of wood put in parallel to the door (when closed) Most wood you buy is the more or less standard 16-17" length.
It is a royal pia to load, and will not take enough wood to hold a burn all night. I normally pride myself on doing plenty of good research before making a purchase like this, but I really screwed up on this one.
Wayne
bob308
09-11-2005, 09:08 PM
last winter we used a palor stove it did good saved us 2 house paymants. the only problem was it was not big enough to last all night. so this year we got a new potbelly so we can put in a load of coal to go all night.
andy_b
09-11-2005, 10:21 PM
i have one of the Vermont Castings stoves with the catalytic unit in it. it was supposed to be the most efficient when we bought it five or so years ago. since then i have heard of folks having trouble with catalytic stoves, but we haven't had any trouble with ours.
my parents have a regular fireplace they use a lot in the winter (not every night). i honestly don't know if my dad has had the flue cleaned more than once or twice. when i put in my wood stove i was under the impression the same held true for a wood stove burning 24/7 for four months. ummmm.., that is not the case. i learned quickly that first season that you probably have to clean it at least twice during the winter months. i usually watch the weather for a clear day with no wind and temps at least in the high 20s. then i'll let the stove burn out that night and it only takes an hour the next morning to clean the flue (i bought the brush and rods for a few bucks at the local stove place).
otherwise we have had a good experience with the stove. i'd definitely do it again. i figure the stove and accessories were paid for by the third year with the savings on heating oil.
andy b.
09-12-2005, 12:00 AM
We have been heating with wood since the 70s. We have a big Fisher wood stove downstairs. It's welded 1/4" plate and firebrick lined inside on the bottom half. It takes 30" logs and is about 2 feet wide and high. It will burn all night plus some. We have three chimney flues in a massive brick chimney that goes from the basement to the roof. It is 8' x 3'. The stove downstairs is right beside it and the bricks heat up after a few hours. The thermal mass is enough to keep the house warm for another 12 hours after the fire is out.
Up stairs in the same chimney but a different flue we have a large fireplace with air circulating passages around and behind the inside firebrick. In this fireplace is what is called a flush insert made of 1/4" steel plate with cast iron doors. It also has built in air circulation passages.
Either one is enough to heat the house but the downstairs stove keeps the basement warmer. We also have several ceiling fans including one that forces air from upstairs down the basement stairs. Above the downstairs stove there is a grate in the floor beside the chimney with a 8" muffin fan below it. This forces hot air upstairs.
The only time we ever put on both stoves is when it gets near -40. We have a well insulated house with all double glazed windows and R60 in most of the attic. In an average cold winter it takes about 6 to 8 cords of pine and fir to heat our house. We don't have hardwood here.
We also have electric baseboard heat as well as a natural gas furnace that requires no electricity.
As per my earlier comment using wood as your primary heat source here can make your insurance sky high or even make it impossible to get insurance. We are ok because we have primary and secondary heat that aren't wood.
I have a bunch of wood this year from my own property due to the beetle kill of all my pines. I still have to get some in but it is all standing deadwood so it is dry.
Wood heat is nice but it is a lot of work. With the price of natural gas predicted to go up 50% this winter I better get some more of that pine in.
Last Old Dog
09-12-2005, 12:40 AM
Chimney fires are SCARY, sounds like a 500,000 BTU propane stubble burner, low frequency roar, but really loud. It burned/melted the wind/rain cap off the top straight away, flames shooting up 2'+, sparks another 4', billowing black smoke like a freight train. It destroyed 7 sections of triple wall stainles flue. The renter had the door wide open trying to "Cool it off". Lucky I happened to be close bye. Last Old Dog
Not affiliated with the esteemed 'Your Old Dog'
SJorgensen
09-12-2005, 01:22 AM
In Salt Lake City it is expected that those gas people will increase the cost of unrefined natural gas 70%.
This will be a tough winter. Yet the consumers will remember this winter for decades to come as we are being subject to the "energy market" with no real alternatives.
Insulation and organic fuel is the answer. Do not pay for oil from the middle east or from any company associated with Dick Cheney or Haliburton.
bobbybeef
09-12-2005, 01:32 AM
Ah you have a fit young wife!
now get her a really good swedish axe and give her room to swing it. you go get the wheel barrow and stack it all in the barn.
Give wife a ten minute break every hour while you hone up the axe edge. you will have a months supply done in no time.
Get real; get a gas heater and a couple of one ton bottles where the truck can get into them in midwinter.
best of luck.
Bobby.
Your Old Dog
09-12-2005, 06:09 AM
When the wife was young and fit we didn't need any heat, we made our own. Now we use a wood burning stove !
Michael Az
09-12-2005, 11:42 AM
While the subject came up, lets talk about what to do in case of a chimney fire. I've never had one but I sleep with fire extuisher next to the bed. Is this the best way to put out the fire? I have never once cleaned out my chimney, I replaced it last year and it had very little creosote build up in it. I don't know why. Maybe the stove is effecent, I just don't know. Living in Az desert with the stove just "idling" so much of the time, { no fire at all during the daytime} I would think it would be prone to buildup. I only burn mesquite and oak and the mesquite does have quite a bit of cresote in it.
Michael
andy_b
09-12-2005, 12:22 PM
Michael,
i know there used to be a product you tossed in the fireplace and it went up the chimney and used up the oxygen to smother the fire. i was also told to close all the vents and doors on the fireplace/stove if possible. i doubt opening the doors and windows to "cool it down" would be the best course of action.
the way my flue is set up i can pull the bottom clean-out off and take the top cap off and look straight up the flue and see the sky. i always check it before i clean it, and while i do get a thin layer of black creosote in the flue, the screen around the top windcap gets covered with creosote long before the flue gets too much. that's actually how i judge when to clean it. when the screen starts looking like it was dipped in thick chocolate oatmeal, i know it's time to clean everything.
andy b.
operose
09-12-2005, 12:56 PM
I put in a cord of rather "freshly cut" (probably a week or so ago) in the back part of the porch last night.. tonight after work I've gotta try and get another 2 cords of the dry stuff in front of it...
winter's coming fast boy, I tell you.. gets down to 40F here at night already and I'm gearing up for the white stuff!!
since I'm the only male in the household, my girlfriend, her mother, and grandmother all appreciate my stacking the wood, Im' sure... but it'd be nice if I could get them all out there helping me!
ahidley
09-12-2005, 01:35 PM
Wood is the MOST expensive heat form that there is....
$300 chain saw
$1000 log splitter
$500 trailer
$500 tractor
$5000 Pickup/dump
$5200 one day a week ($100/day)(adverage)all year preparing for winter- cutting, splitting, stacking, moving, stacking, moving
$200 rear pickup truck window
$3000 micro surgery for hand cut buy saw
$100 gas and oil for saw, truck, tractor, splitter
$15800 / year.....
Priceless.. Yes I heat with wood too.. I love it....
operose
09-12-2005, 03:05 PM
$300 chain saw
$1000 log splitter
$500 trailer
$500 tractor
$5000 Pickup/dump
$15800 / year.....
all depends on how you go about it, I guess.. I don't have a tractor or a wood splitter or a nice new chain saw or a shiny new window for the back of my pickup truck..
09-12-2005, 03:16 PM
Heh. After getting wood this summer I don't have any window in the back of my Land Rover...
operose
09-12-2005, 04:05 PM
I've been quite successful in keeping all of my rear windows in tact! guess I'm lucky in that respect
09-12-2005, 04:44 PM
Well, the Land Rover window lasted 46 years. I have a spare.
IOWOLF
09-12-2005, 06:15 PM
<font face="Verdana, Arial" size="2">Originally posted by ahidley:
$300 chain saw
$1000 log splitter
$500 trailer
$500 tractor
$5000 Pickup/dump
$100 gas and oil for saw, truck, tractor, splitter</font>
Thats just silly, cut wood not your hand,build your splitter,and if your are not doing something for profit you are not worth $100 per day. http://bbs.homeshopmachinist.net//smile.gif
The tame Wolf !
charlie coghill
09-12-2005, 06:22 PM
I did not loose a back window but did loose a review mirror.
Stanko
09-12-2005, 06:40 PM
$300 chain saw
$1000 log splitter
$500 trailer
$500 tractor
$5000 Pickup/dump
you dont buy a new saw each year or a tractor or a splitter or a trailer or a truck which you probably already have (wife has the spare) so we are just down to the medical , window , fuel. If you read the instructions on the saw its just the fuel and the window.
Your Old Dog
09-12-2005, 06:57 PM
After all the talk the past few days about home heating cost for this winter I was still able to buy 4 more cord of maple for $200.00 from an old farmer. He has corn to get in and his tractor gearbox spread from one end of the barn to the other. Must be too busy to watch the news the past few days. I don't think much grass grows under these guys feet !! He'll get even with me next year http://bbs.homeshopmachinist.net//biggrin.gif
forgot to add, it's seasoned one year. Light greyish in color and lightly checked on the ends!
[This message has been edited by Your Old Dog (edited 09-12-2005).]
bob308
09-12-2005, 08:03 PM
if you have a chimney fire. spry water on the fire the steam will put the fire out some times. that is what the fire dept. told me.
bob308
sandman2234
09-12-2005, 09:18 PM
I had a chimney fire once. A little different from most. Mine came from a fireplace insert not quite put in to specification. The line for non combustibles wasn't adhered to, and the sound of smoke detectors woke us up. Seems the imitation rock had been laid on a plywood base, and that was burning from inside. Only thing we saw was the glow under the mantle. Water hose took care of it thank goodness.
David from jax
Last Old Dog
Michael, in my case the stove is an 'air tight' home made of heavy plate. 8" flue top exit, straight up to the ceiling, then stainless triple wall through the roof, no bends. I generally brush the flue thrice a season, judgeing by the accumulation of creosote on the cap screen.
I have water already plumbed to the stove for the water back so in an 'emergence' a simple valve introduced water to the fire box up high. NOT low, or hot embers will be carried out and then reignite in the fresh oxygen. Water expands 1500-1650:1 so with the door and cumbustion air closed off, pulse short spurts of water into the box.
Too much water at one time will cause thermal shock and perhaps damage to the stove hull, refractory and/or flues. CO2 is also effective, but with the chimney effect, it clears in a hurry and does not cool anywhere as well as converting water as a liquid to a gas. My rule is keep it clean, no big roaring fires, and have a hot glove ready to take any action.
One of the guys leasing acrage on the property has a tree service, all the wood we can use but better yet, we start our fires using a #10 shopping bag stuffed with dried chips from his big wood chipper. One match, lotsa surface, quick warm up. Last Old Dog
Not associated with 'Your Old Dog'
fixxit
09-13-2005, 12:42 AM
I installed my wood stove during the late 1970's. It was a Vermont Castings Vigilant model.
A few months after the installation I was awakened by our smoke alarm going off at about 2AM. I went into the stove room and was very surprised to see the stove pipe that connects the stove and the chimney glowing a bright cherry red. This was the first time I had ever seen a chimney fire.
The factory paint on the stove pipe had burned off because of the heat, and set off the smoke alarm.
I shut off the air supply vent into the stove and the red glow of the stove pipe gradually faded. This was a wake up call to change my ways.
I purchased a set of fiberglass rods and a chimney cleaning brush and cleaned out the chimney. Then did a lot of reading about wood stoves and chimney fires.
I finally settled on making smaller burns, but keeping it very hot. Long smoldering burns that produce lots of visible smoke waste fuel and lead to creosote deposits.
[This message has been edited by fixxit (edited 09-13-2005).]
Michael Az
09-13-2005, 01:14 AM
bob308, thanks for bringing that up but that was the last thing I would have thought of because of the fear of damaging the iron stove, but I could see a smaller amount of water and keeping it off the iron. I had better bring in a garden sprayer full of water for the winter season.
Last Old Dog, it sounds like you have a good system set up. What do you think about my garden sprayer idea?
fixxit, I believe it was your lucky day that you might have saved your home from fire! I don't understand why my chimney stays clean because the stove does so much idleing. Here in Az we have cold nights and warm days so can't keep a big fire going. Maybe the low humidity has something to do with it.
Michael
ahidley
09-13-2005, 07:15 AM
Yes, The dry air is likely the key.. If the wood is dry then there will be little creosote buildup. Also if your chimney is short and the smoke exits before it cools then there will be no buildup.
If yu guys like building stuff, which most of us here do, then look up a "russian stove" Thats a cool way to heat the house......
http://www.russianstove.com/
torker
09-13-2005, 07:59 AM
Yes wood heat is worth it if you can get or buy wood cheap enough. I heat my shop for about $20 a month in the winter. (Which is here BTW...we had over a foot of snow just down the road from us on Saturday)
Yes it is messy and it's hard work. I need the exercise anyway.
I drive a pickup for other things anyway so that part is a done deal.
Buy a decent saw.....AND LEARN HOW TO SHARPEN IT!!!!!
That's probably the biggest downfall for most people. The saw cuts crooked and they get into trouble trying to fall trees or buck off large blocks.
When the saw cuts croaked it wears the bar and chain out fast.
A pro saw will last two years or more, 8 hours a day running time. I bought a smaller saw to cut firewood with. A Stihl 044(used to run 066's). Cost $1400 but will last for years just running 5 or 6 hours a year.
A cheap POS saw may only last a short time.
Put your wood up off the ground when you cut. Make sure there are no rocks stuck in the check and don't push on the saw at the end of the cut.
I bought my saw three years ago and cut 4 to 5 cords a year. Have only sharpened it three times.(but I too will hit a rock eventually http://bbs.homeshopmachinist.net//biggrin.gif )
Oh ya...pouring water in the stove does help with a chiminey fire but make sure to pour some in from the top also...if you let the chiminey get that dirty (shame)
I've been burning wood my whole life and have never had a chiminey fire but have seen a few neighbouring houses burn down from them.
We ALWAYS start the fire with small wood and get it really roaring to heat up the chiminey. This is repeated a couple times during the day as well.
Russ
Your Old Dog
09-13-2005, 08:01 AM
In this part of the country many folks let the fire burn hot when they first lite it. This cooks off any creosote from the tail end of the last burn. That explains why so many folks around these parts don't have that big a problem with creosote buildup.
Creosote won't form as readly on the hot part of the chimney as it will near the far end where it's exposed to the elements is much cooler allowing the creosote gases to form inside.
BTW, you can't shut off the air intake on most new woodburners. You simply change the direction the air comes into the stove from (Above or below the firebox) With many new stoves, when you think you are cutting off the air your are actually directing it to enter the stove from above the firebox. (again, clean air burn efficiancy taking president over the ability to starve a fire for oxygen as in a chimney fire) God save us from those who seek to save us.
