View Full Version : How do I cut a spiral?
AZSORT
09-12-2005, 01:08 PM
I've got a buddy that wants me to make him a pair of 12'plastic discs with matching spiral v-gooves in them (mirror image) that have a 1/4" offset per rev. It will be a reel for holding large photo film in a developer tank. This is too wide for my micro CNC and it is just a one off of course, so tried to do it manually on the BP. But cranking the rotary table for all I was worth while the table feed went as slow as it would go gave about a 1/2" groove offset. Made a coupler to socket a drill drive speed reducer to the rotary table and got the offset down to almost 1/4" but the feed speed on the outside of the spiral was so high (3"/sec) that the cut goes bad. This is too much swing for my little lathe so I'm all out of ideas and so am turning to you wonderful people for how to do this right short of buying an A-axis for the MAXNC.
Mcgyver
09-12-2005, 02:03 PM
I think you ruled out the obvious ones - but somehome, either mechanically or electronically, the linear and rotary axis must be connected. ie that already exists with the lathe mechanically or electronically for the cnc.
the solution depends on how much trouble you want to go to - so my idea is to simplify that connection (instead of gears etc)
what about a small steel cable (model airplain control line stuff) wrapped around a cylinder on the rotary table handle, the going to a homemade pully bolted on the corner of the table (used to change direction, like a bell crank) and from there to cylinder where the axis mill handle used to be. Rotating the table also rotates the linear axis screw??
[This message has been edited by Mcgyver (edited 09-12-2005).]
topct
09-12-2005, 02:17 PM
First take the lead screw out of the mill table so it can move freely. Then a post in the center of the rotary table with a cable attached to it and anchored to the bench or wall. As you turn the rotary table the cable will pull the mill table, thus creating a spiral.
And now we will hear from someone that really knows what they a talking about. http://bbs.homeshopmachinist.net//smile.gif
Gene
09-12-2005, 04:20 PM
Sounds like a place for the dividing head or rotary table, geared to the table feed. That way you can set up any feed per turn you want, so long as you have the gears for it.
AFAIK that is the standard way to do it. Drive hooked into the fastest rotation, which would be the head/table, and the takeoff from that going to table drive.
winchman
09-12-2005, 04:31 PM
All the film reels I've seen were made of wire welded to several U-shaped spokes, like this:
http://www.calumetphoto.com/ctl?PAGE=Con troller&ac.ui.pn=cat.CatItemDetail&ac.item.itemNo=CP9076&ac.cat.CatTree.detail=y&type=PRDINDEX (http://www.calumetphoto.com/ctl?PAGE=Controller&ac.ui.pn=cat.CatItemDetail&ac.item.itemNo=CP9076&ac.cat.CatTree.detail=y&type=PRDINDEX)
There are some made of plastic, but they are similar. That design allows the best flow of the processing solutions around the film. I don't see how you could have adequate flow with grooves cut into two discs of plastic, unless you're going to drill a gazillion holes, too.
Roger
[This message has been edited by winchman (edited 09-12-2005).]
topct
09-12-2005, 06:26 PM
The key words here are "I've got a buddy that wants"
Thanks Winchman, http://bbs.homeshopmachinist.net//biggrin.gif
Gene
IOWOLF
09-12-2005, 06:33 PM
<font face="Verdana, Arial" size="2">Originally posted by topct:
</font>
Is that like, Do me a favor and........
The tame Wolf !
Paul Alciatore
09-12-2005, 06:36 PM
I'm with Roger. All the film reels I have seen were either SS wire welded to spokes or molded plastic. I would think about the SS wire and a way to hold it in a spiral. A tack welder would be great, perhaps with special tips to conform to the wire.
Or, make a mold with a flat plate and epoxy a wire spiral to it. Use it to make a rubber mold or use it, itself as a mold and pour some plastic molding compound. I think this would be easier than milling a spiral.
One more thought. For film, it does not have to be a perfect geometric spiral (and there are several types). So what you could do is use the lathe to turn a series of uniformly spaced circular grooves on the face of a plate. Cut another plate with grooves where the lands are on the first and lands where the grooves are. Then cut the plates in half on a their diameters and DEBUR.
Now reassemble one half from one plate with one from the other plate on a backing plate but offset them so that the lands match lands and the grooves match grooves. Use a good waterproof adheasive to join them. When you do the second pair, be sure to do the offset in the OTHER direction. This will make two spirals that wind in opposite directions.
Paul Alciatore
09-12-2005, 06:43 PM
Yes to the circulation thing. I have done some darkroom work and can assure you that it will need lots of holes for the chemicals to circulate. Used up developer needs to be circulated away from the fiml and fresh developer needs to get to it on a continous basis. And for proper development, that process needs to be uniform at all places on the film - edges; center; inside, middle, and outside of the spiral. For a five or ten minute development we used to agitate every 20 or 30 seconds. More often for shorter periods.
The film holders I have seen for larger film (line 5x7 and 8x10) have held it flat, not in a spiral.
winchman
09-12-2005, 07:01 PM
How about this?
Take a long piece of copper wire (maybe #8) and bend it into the spiral you need. Leave enough at each end to bend down for attaching leads from your welder or battery charger. You'll have to drill two holes in one of he discs for these ends to pass through.
Put a piece of particle board on blocks, and put the disc with the holes on top of it. Drill matching holes through the particle board. Put the spiral in place, and connect the leads to the ends poking through the holes. Put the other disc on top of the spiral, and weight it down evenly. Make sure everything is lined up like you want it.
Apply just enough current to get the wire hot enough to sink it slightly into the plastic discs. Now you've got each disc marked for where the spiral needs to be, but the grooves aren't deep enough yet.
Now remove the top disc, and put some spacers around the edges of the other one. You just want something to set the depth the wire can go into the disc. Put the partical board on top of the spiral, and weight it down as before. This time apply a bit more current, and let the weight press the spiral down until the spacers are holding the particle board.
Repeat the process for the other disc. You'll have the two discs with mirror image grooves of the same depth.
With a little luck that should give you something he can use. Winding the spiral will be the tough part, but putting some spacers between the wraps as you go should give you something pretty close on the spacing.
Roger
09-12-2005, 07:09 PM
Convince him to buy a digital camera.
egpace
09-12-2005, 07:19 PM
</font>
The only way to properly end that quote is...
...to by me a case of beer." http://bbs.homeshopmachinist.net//biggrin.gif
Have fun,
Ed
09-12-2005, 09:16 PM
The circulation shouldn't be a BIG problem, I'd just mill in some fairly wide radial grooves from the smooth side, deep enough to intersect the spiral.
The spiral can be pretty loose, the usual metal ones are...
The plastic ones I have from the B&W days are basically the spiral with intersecting grooves. If agitated, it should slosh well enough to work perfectly, if the grooves are wider than the spokes.
You DO want the grooves smooth and a very even spiral, so the film slides through easily. If it folds and scrapes against itself, you can lose emulsion.
AZSORT
09-12-2005, 10:22 PM
1. He's a proffessional photog and passed the cost-is-no-object hurdle. He's got an automated machine from the 70's that you can't get parts for.
2. Has the little wire reel deals but needs to be able to do film 5" wide by 30 feet long.
3. Decided that holding this wide film by its edges in grooves might not be safe with irreplaceable negatives.
4. Came up with a way to make a reel consisting of a spiral pattern of rods that he'll have to slip into it while winding on the film (in the dark). Main consideration is to not let anything touch the elmusion during the process.
Thanks for the ideas
Greg C.
09-12-2005, 10:28 PM
5" wide.... http://bbs.homeshopmachinist.net//eek.gif that could be a problem with rubbing together.
I don't have any ideas for that.....
chiphead42
09-12-2005, 10:37 PM
Look for industrial xray supply, nondestructive testjng, they use large reels some are ajustable width. chiphead42
Boots
09-14-2005, 04:37 AM
Hi One thing to remember is that the spiral has to be done in opposite directions as they are two different sides facing each other.
The other thing is they have to be really smooth or the film will catch on the way in.
I would think the best way to do this is make them out of stainlesss wire and tig the spokes on.
Make a template you can lay your wire on from both sides or draw it out on paper and drive nails into some plywood following the lines and wrap the wire along these silver solder may be an alternative joining method.
Your Old Dog
09-14-2005, 06:07 AM
If you can't talk him into digital then try doing it using a wood router on a workbench.
Mount the router on a track that goes from center of circle to edge and start at the outside of the circle. As you turn the circle by hand a cord could wind around the pivot point and advance the router. Your origianl post clearly states 12' and not 12" right?!
Otherwise, I'd buy a few hundred of'em off ebay and experiment with modifying them to your needs till you got a set that worked. It would be far easier to make a jig to modify what you can easily locate.
Failing that, look for another friend and be more careful who you choose next time. I find when you got a lathe/mill you attract such dreamers like a magnet http://bbs.homeshopmachinist.net//biggrin.gif
deanrach
09-14-2005, 06:50 AM
Our CNC Mills have a working envelope of 16" x 12" on a table size of 12" x 36". I would be interested in taking a closer look at the project an possibly propose that my second year Associate Degree students make the parts for you. Your only expense would be materials and freight.
<font face="Verdana, Arial" size="2">Originally posted by AZSORT:
I've got a buddy that wants me to make him a pair of 12'plastic discs with matching spiral v-gooves in them (mirror image) that have a 1/4" offset per rev. It will be a reel for holding large photo film in a developer tank. This is too wide for my micro CNC and it is just a one off of course, so tried to do it manually on the BP. But cranking the rotary table for all I was worth while the table feed went as slow as it would go gave about a 1/2" groove offset. Made a coupler to socket a drill drive speed reducer to the rotary table and got the offset down to almost 1/4" but the feed speed on the outside of the spiral was so high (3"/sec) that the cut goes bad. This is too much swing for my little lathe so I'm all out of ideas and so am turning to you wonderful people for how to do this right short of buying an A-axis for the MAXNC.</font>
winchman
09-14-2005, 09:33 AM
"The other thing is they have to be really smooth or the film will catch on the way in."
That's not a problem. The film is squeezed to fit between the sides of the reel to get it started. As the film bends, it straightens out, and fits into the grooves. Once bent into a curve, the film stays straight from edge to edge. That keeps the emulsion from touching anything while on the reel.
It's really quite easy to load a reel, even in total darkness.
I'm speaking from experience with 35mm and 120-size film. Five-inch film may be a little different.
Roger
[This message has been edited by winchman (edited 09-14-2005).]
jcc3inc
09-14-2005, 10:13 AM
Azsort,
If you would like, I could make a CNC program for you which has a continuous spiral made of short straight line segments. It can have any number of segments per revolution and any number of revolutions. I once made an ellipse program generated from straight line segments, and number of segments, and size.
A second approach would to make the spiral from (4) circular arcs per revlution, with as many revolutions as required.
In either case, the program would allow the user to select the variables, and generate Gcode for use on the CNC.
Regards,
Jack C.
Paul Alciatore
09-14-2005, 11:12 AM
30 feet long??? I have used the small reels for 35mm and 120/220 film and had trouble loading the film into them. 30 feet is going to be a challenge.
As far as I know, three loadnig methods have been used. Fixed reels are loaded by starting the film at the outside of the spiral and pushing it in. ANY thing that catches the film will hault this process and may even require that it be taken out an started over. I don't recommend this method for short strips much less 30 feet.
Some reels have one side (one spiral) mounted so that it can rotate a small amount (20 - 30 deg). Then the film can be started at the outside and by rotating that side back and forth with thumb pressure alternating to hold the film fixed on the two sides in turn, the film is loaded fairly easily. This method is a good advantage over the simple push it in technique because it cuts the friction in half. I don't know if it would work with 30 feet.
The third method uses a fixed reel (no rotating sides) and a loading shoe that forms the film in an arc so it can fit between the spirals. Loading is started from the center and by turning the reel it progresses to the outside. Sometimes fingers are used instead of the actual shoe to do this. I think that this technique would stand the best chance of success with such a long piece of film. If this third technique is to be used, be sure that the lands of the spiral have very smooth and round edges.
I don't think that adjacent layers will be in any great danger of touching. The spiral shape of the film will be very effective in preventing that even at fairly close spaceing. Of course, it will need to be loaded properly, with NO KINKS. Been there, done that. Ain't no fun.
As for the 30 foot length, I would think that a stand that holds the film, the spiral reel, and any loading aid would be almost a complete necessity. It would be a bitch holding those three elements for 5" wide film in the dark and doing the loading without kinking the film. With a proper loading stand, the job would be a snap. You could even motorize it. A SLOW motor, please.
Interesting project!
AZSORT
09-14-2005, 07:46 PM
Well, decided to not try a spiral grooved reel as, in playing with 5" wide film, feel that it will be too problematic in loading the film. Going to try an 8 spoked reel with 1/8" crossbars on 1/4" spacing down the spokes - kind of like a ferris wheel. The crossbars will be just simple rods that slip in through holes from the side. He will have to insert all these rods while winding the film on under tension.
I'll let you know how it works out.
Greg C.
