View Full Version : welding safety question
Benjamin Borowsky
10-09-2005, 07:17 PM
I just tried out my new autodarkening helmet, with my new mig welder.
(Off topic, I didn't know it was POSSIBLE to mangle a weld that badly! - practice better make perfect!)
I ran a quick line, about four inches. When I was done, I had a bright afterimage in my eyes, that lasted over 1/2 hour. (It obviously dimmed over that half hour, but was pretty bright in the first few minutes.)
I have no experience at all with welders. Is this normal, or are my panic insticts correct, and this is very bad?? How do you know if the helmet is working properly?
Thanks in advance for answers. I just think there are more fun ways to go blind...
hoffman
10-09-2005, 07:28 PM
I welded for a few hours the other night with my HF auto dark hood and didn't have any problems. I had the shade set on "10" and it set to "fast".
Mine goes from 9-12.
That doesn't sound good...
gkman11
10-09-2005, 07:38 PM
I'm a novice welder using a MIG machine and a cheap auto darkening hood. I have never had that experience. Scares me.
greywynd
10-09-2005, 08:40 PM
There should be a spot to adjust the shade, I would think for mig work you would want a minimum of 9 or 10, going up to 12 even if running heavy current. One of the things about using auto darkening helmets is that I tend to set them darker than I would if using a comparable 'normal' helmet, because I'm not trying to hold everything 'just so' when I flip the helmet down.
Mark
torker
10-09-2005, 09:25 PM
Ben...if it is new..and if it's solar, was it charged? If it's not set out in the light it won't have a charge and the lens won't darken.
The way I check mine is flick a striker or even shine a bright light in front of it. It should darken immediately.
Russ
charlie coghill
10-09-2005, 09:26 PM
Make sure that the helment is working.Dimming when it is supposed to. Have some one that is experienced check it out.
A bright afterimage is not good I don't think.
I have never had a problem with my Auto darking helment. Better not have as it was 286 dollars.
andy_b
10-09-2005, 10:22 PM
Ben,
definitely get the helmet checked out. you should NEVER see a bright after-image like that while welding. if you do, STOP and see what is causing the problem.
it sounds like you are going to be okay, but BE CAREFUL!
andy b.
Benjamin Borowsky
10-09-2005, 10:35 PM
Yes, I charged it. Yes, that's what I thought.
Thanks.
It's getting returned immediately - it was a home depot $99 special...
It was supposed to be a 10.5, and it WAS darkening... but clearly not enough.
I appreciate it, guys.
Tinkerer
10-09-2005, 11:06 PM
If your seeing a ghost image the shade is not dark enough. For stick welding it needs to be 12/13 for mig/tig 10/11. You should get a variable shade 9-13.
Smokedaddy
10-09-2005, 11:34 PM
Not sure if I understood your posting but -IF- you fried your eyes, you'll know about bed time tonight.
-SD:
david_r
10-10-2005, 12:52 AM
Benjamin,
Don't sweat damaging your eyes. Contrary to internet voodoo, a non-functioning auto-dark helmet still blocks the UV light, so you won't burn your corneas. However, the bright visible light can't be good for your eyes, long-term.
10-10-2005, 01:50 AM
David is correct. Here is an excerpt from the specs for a Miller helmet:
"Light State #4, provides continuous UV an IR protection"
http://www.millerwelds.com/products/weldinghelmets/xlix.html
Your Old Dog
10-10-2005, 09:09 AM
Ben, once the arc is started all I see is the weldment puddle because the shade darkens down. Mine goes from 9 to 12 and when Mig welding I set it at around 11 because I'm still learning and want to actually see the molten metal in the bead.
Sounds to me like your's isn't charged up or may be defective but you shouldn't have an after-image like you do.
Norman Atkinson
10-10-2005, 03:20 PM
I belong to a much older generation than most. Before returning the mask to the dealer have it checked but more importantly, have your eyes checked for corneal burns.
The latter was what WW2 troops in the Western Desert got from using binoculars.
Norman
hoffman
10-10-2005, 07:53 PM
Norman knows. He polished Monty's knob at El Alamein.
zl1byz
10-10-2005, 08:05 PM
Fortunatly as someone pointed out in the other thread about these auto dark lenses they block all the harmfull radiation even when light. They darken so you don't get blinded by the glare.
John.
speedy
10-10-2005, 08:46 PM
<font face="Verdana, Arial" size="2">Originally posted by hoffman:
Norman knows. He polished Monty's knob at El Alamein.</font>
"Monty, my part in his downfall" by Spike Milligan... er Norman http://bbs.homeshopmachinist.net//smile.gif http://bbs.homeshopmachinist.net//smile.gif??
Ken
Norman Atkinson
10-11-2005, 11:23 AM
Hoffman- nice one!
Remind me that I owe you one. Is this going to be the Patton for the future? How's that for military history!
It is interesting to think just how much damage that Spike and the rest of the boys got in the Western Desert. Spike wasn't a well man- despite the humour of the Goons.
Hallow, Jeem and who is in the barrel this week? Neddy Seagoon and Eccles- you dirty rotten swine- you! Major Bloodknock and*****
And one for you-
"He's fallen in the water"
Straight out of the Goon Show.
And one from ITMA- It's that man again!
"Don't forget the diver"
Well, me old friend, English Humour at its best.
TTFN
speedy
10-11-2005, 04:57 PM
My children never tired of "Badjelly the Witch" --fluffybum the one eyed cat http://bbs.homeshopmachinist.net//biggrin.gif http://bbs.homeshopmachinist.net//biggrin.gif and Jim the heroic eagle.
On second thought it was I who never tired of reading it to them http://bbs.homeshopmachinist.net//smile.gif ......they never complained though....honest!
Years ago, I saw Spike at a show here in NZ ....fabulous. I love that humour!
Ken
