View Full Version : Van Norman Mill Drive Chain
SaratogaBill
10-12-2005, 08:32 PM
I recently acquired a Van Norman #12 in pretty good shape. However, the chain drive (toothed chain)for the power table will not stay on the gears. I'm told there is a different way to adjust the tension. Can anyone help?
Thanks, Bill
rockrat
10-12-2005, 09:18 PM
I have a VN but it is the bigger 22L.
You might try
http://finance.groups.yahoo.com/group/vannorman/
I go there often when I need advice on mine.
rock-
SaratogaBill
10-13-2005, 10:41 AM
Thank you, sir, I'll give it a try. The 12 was heavy enough to get out of the previous owners cellar. It doesn't look like the drive has worked for awhile.
Bill
<font face="Verdana, Arial" size="2">Originally posted by rockrat:
You might try
rock-</font>
cijuanni
10-13-2005, 12:23 PM
The motor slides left and right to adjust chain tension.
SaratogaBill
10-15-2005, 08:20 AM
I found that. The problem is that when you snug the chain up and rotate the drive by hand, after a couple of revolutions, the chain jumps and locks up. Trying to find out if the chain should real tight, slack or somewhere inbetween.
Thanks, Bill
