I am looking for a source of a good, high quality table top drill press. I would love to have a keyless chuck, variable speed and dynamic braking, but I might not be able to find all three items on one unit. Any suggestions on brands?
drill press
Can't help with the keyless chuck, and you may not want it with dynamic braking. Set the DP with a VFD and hook up some external braking resistors and you're in business. That what I did to one of my lathes, and I stop it in 2 seconds from 4000 RPM.
Harry
Most keyless chucks go on a threaded arbor. Most table-top drill presses have a JT33 arbor. Some will have a Morse taper. One way to get keyless action, plus good accuracy, would be to buy a Wahlstrom chuck from Ebay etc. to fit a JT33 or MT arbor (depending on which press you have).
Not sure what the need for dynamic braking is. In my experience, drill presses stop pretty quickly. If it's just so you don't wait between drill changes, the Wahlstrom chuck will do that for you -- production operators change tools without even shutting off the drill press.
While it's old technology -- VFD-driven makes more sense -- I'm partial to the manual cone-drive pulley drill presses. There's something satisfying about dialing in just the right speed on these.
So, maybe a used Clausing, Rockwell, Delta benchtop variable speed drill press, plus a Wahlstrom chuck?
