View Full Version : Gears
Fasttrack
11-02-2005, 07:47 PM
Sorry posting this again...i am sure i read a post about it earlier but i couldnt find it...
Can someone tell me how to determine pressure angle and pitch on a miter gear?
speedy
11-02-2005, 08:10 PM
Seek and so shall ye find sayeth the Lord
http://bbs.homeshopmachinist.net//Forum1/HTML/013429.html
http://bbs.homeshopmachinist.net//Forum1/HTML/012616.html
or I will look for you http://bbs.homeshopmachinist.net//biggrin.gif
Ken
Fasttrack
11-02-2005, 09:56 PM
Thanks! Somehow i did a search and couldn't find anything...wonder what i did wrong...oh well! Thanks alot!
Only one problem...the gears are miter gears from a differential. Does that change things? It sure makes the geometry of the teeth funky! What else, besides pressure angle would be needed for a miter gear?
11-03-2005, 12:07 AM
According to a book I have (Elements of Mechanism) the important measurements for a bevel gear are:
Root diameter
Pitch diameter
Outside diameter
Back cone distance
Bevel gear nomenclature is:
Pitch cone = The imaginary cone on which the teeth are made
Cone distance = The length of the side of the pitch cone
Pitch point = The point of tangency of the pitch cones at the large ends
Cone angle = the angle which an element of the pitch cone makes with the axis of rotation of the gear
Face angle = angle which the top surface of the tooth makes with the axis of rotation
Addendum angle = angle which the top surface of the tooth makes with the cone distance
Root angle = angle which the bottom of the tooth makes with the axis of rotation
Dedendum angle = angle which the bottom surface of the tooth makes with the cone distance
Back cone distance = distance along the element of the back cone from the pitch point to the axis (center line) of the gear
Virtual number of teeth = number of teeth contained in a spur gear whose pitch radius is equal to the back cone distance and whose pitch is the same as that of the bevel gear. Since it is imaginary it may be fractional.
I can post a drawing of this for you tommorrow if you wish.
Fasttrack
11-03-2005, 08:12 PM
A picture would be great! Thanks alot!
11-04-2005, 12:56 AM
I'll put it on in the morning.
11-04-2005, 10:40 AM
Here you are. This is from the book Elements of Mechanism, published originally in 1904 by John Wiley and Sons and authored by Peter Schwamb, Allyne L. Merril and later editions with Walter H. James. It deals in detail with all the sorts of mechanisms found in industrial machinery with emphasis on their use in the sorts of machines found in shops as well as dealing with the practicality of constructing such mechanisms.
It is an excellent book for anyone designing machinery and is still available used. It is fairly heavy on the math involved but even without the math it is still useful.
This is from the very complete chapter on gear design.
http://vts.bc.ca/pics/bevel2.gif
http://vts.bc.ca/pics/bevel1.gif
http://vts.bc.ca/pics/bevel3.gif
http://vts.bc.ca/pics/bevel4.gif
http://vts.bc.ca/pics/bevel5.gif
[This message has been edited by Evan (edited 11-04-2005).]
Georgeo
11-04-2005, 10:59 AM
You said these bevel gears are from a differential? In that case I think they are probably Hypoid gears, not regular bevels. Hypoids are used where the centerlines of the shafts involved are perpendicular, but do not intersect.(To visulize,think worm and worm gear, but with the teeth on the side of the gear, not the rim) The teeth are curved in a strange way, something like a spiral bevel gear, but not the same at all. A good gear text would discuss these.
Hope this helps a little.,
George
11-04-2005, 11:43 AM
There are many variations that the above book deals with including crown gears, spiral bevel, skew bevel, helical, hyperboloidal, internal bevel, screw gears and hypoid gears.
Fasttrack
11-04-2005, 03:07 PM
Thanks so much everyone! They are just oridinary bevel spur gears; i neglected to mention that this is a differential from a rinding lawn mower...nothing fancy!
Luckily i found a replacement (with a few modifications anyway...should be fun...get to use my lathe some more!!) from my school. Best thing is, it was free!
Thanks again
