View Full Version : Gear cutter question??
torker
12-13-2005, 07:29 PM
Hey all!
I can't remember this...if a cutter IS NOT marked as to which PA it is...do we assume it is 20 deg?
I was just going through some cutters I got off Fleabay a while ago and one is a 14 1/2 deg. It's marked on the side that you couldn't see in the picture. I forgot to ask..grrr!
Just wondering for future purchases.
(Ha...I scored three 14DP cutters today!)
Thanks!
Russ
12-13-2005, 08:16 PM
Never had that problem before.I wouldn't assume that thou.it would be imbarassing to cut a gear and hand it to a customer only to hear"uhhhh...this thing don't mesh" http://bbs.homeshopmachinist.net//biggrin.gif
SGW
12-13-2005, 08:34 PM
I don't think that's a valid assumption. I think the most you can assume is that it's probably not the P.A. you need at the time. http://bbs.homeshopmachinist.net//biggrin.gif
JCHannum
12-13-2005, 08:52 PM
It is probably safer to assume an unmarked cutter is 14-1/2*, as many were made before 20* existed.
torker
12-13-2005, 10:49 PM
Thanks for the advice guys...LMAO! http://bbs.homeshopmachinist.net//biggrin.gif
JC...I think I had it backwards then. Like I said...I couldn't remember. I think Sir John may have told me that last year...for all the good it did....lol!
Thanks again!
Russ
vmil3
12-14-2005, 03:48 AM
If those were the cutters from Canada, they were "Bevel Involute" gear cutters for cutting bevel gears, not the same as normal 14-1/2° PA involute gears. The cutter's tooth profile is more straighter than the normal involute cutter. I was out bid on the 6-16 DP "bevel involute" 14-1/2° cutter.
Doug
torker
12-14-2005, 07:23 AM
<font face="Verdana, Arial" size="2">Originally posted by vmil3:
</font>
Doug...that'd be the ones. I knew they where for bevel gears but didn't read up about the difference in the PA. JT's writeup about cutting bevel gears sparked my interest. I did see a few people bidding on the cutter you where after.
Russ
