View Full Version : Backhoe Main Pin Boring
Flash319
12-18-2005, 07:25 PM
I finally got around to using the great ideas that I got from you guys on here for boring. Here are some pics of the Main pin holes for the backhoe.
http://img.photobucket.com/albums/v509/flash319/S3000048.jpg
http://img.photobucket.com/albums/v509/flash319/S3000047.jpg
Flash319
12-18-2005, 07:28 PM
Here was the setup but better clamping after this pic was taken.
http://img.photobucket.com/albums/v509/flash319/S3000013.jpg
SVS
12-19-2005, 06:05 AM
Took a long time to get your pictures up with my dial-up connection, but the third picture was worth the wait.
Must have been a tricky job getting that up on the lathe and getting it on center. I am impressed.
Scott
spkrman15
12-19-2005, 07:50 AM
Looks Good. I hope those photos i sent you helped out.
What are you making the bushings out of?
How are you holding them in?
Rob http://bbs.homeshopmachinist.net//smile.gif
Flash319
12-19-2005, 09:37 AM
The holes were so bad that I more or less eye balled it on center. I turned the cutter backwords by hand and got it close to center. The bushings will be made of steel and hardend. I would rather make new pins later then bushings.
