View Full Version : Refurbished Radius Tool
CCWKen
12-19-2005, 05:17 PM
This is the Threadwell Radius Tool I picked up at the salvage yard Friday. After a night in an electrolysis tank and some cleaning and oiling, (maybe a splash of paint too) the finished Radius Tool is below. Not bad for $2.60 and some elbow grease.
Before:
http://img.photobucket.com/albums/0903/CCWKen/Tools/Machine/Radius/RadiusTool001.jpg
After:
http://img.photobucket.com/albums/0903/CCWKen/Tools/Machine/Radius/Radius-Tool-After-011.jpg
http://img.photobucket.com/albums/0903/CCWKen/Tools/Machine/Radius/Radius-Tool-After-006.jpg
http://img.photobucket.com/albums/0903/CCWKen/Tools/Machine/Radius/Radius-Tool-After-010.jpg
IOWOLF
12-19-2005, 05:22 PM
Now that is nice . Thanx for showing us Just how lucky you are. http://bbs.homeshopmachinist.net//wink.gif
The tame Wolf !
lynnl
12-19-2005, 05:28 PM
WOW! It came outta the tank with a fresh coat of paint! It's a miracle.
Kidding aside, that looks great. Bet'cha can recoup the $2.60 from under the cushions on your sofa.
topct
12-19-2005, 05:31 PM
That's amazing.
Gene
12-19-2005, 05:58 PM
That's nice,now send it to me so I can show you how to use it http://bbs.homeshopmachinist.net//biggrin.gif
hoffman
12-19-2005, 06:31 PM
Looks great Ken! A lot of folks are quick to write off stuff that has a lot of life left in it...
J Harp
12-19-2005, 06:40 PM
Very nice job. Please tell us what machine it's used with and how it does what its made to do, can't figure out the christmas tree knobs. thanks.
Jim
aboard_epsilon
12-19-2005, 06:51 PM
Great job Ken
any pics of it just out of the tank .
did you pull all those brass bits off .
or did it eat the rust from underneath of them .
all the best.mark
CCWKen
12-19-2005, 07:14 PM
It's used to grind a radius or shape on grinding wheels. But... I may find some other uses. http://bbs.homeshopmachinist.net//biggrin.gif
http://img.photobucket.com/albums/0903/CCWKen/Tools/Machine/Shapes.gif
The larger knurled wheel is a lock nut. When loose, the middle knob rotates the entire front between movable stops. The stops can be adjusted to the degree wheel. There's also a venier scale at the top to divide the degees into five(I think) minute increments.
The small knurled wheel at the rear is the off set adjustment. It moves the cutter assembly left and right. (When the lock levers are released.)
The knurled knob on top is the height or radius adjustment. It's marked in thousandths (0-50). The brass scale/index on the side shows the radius in tenths of an inch.
Clear as mud?
Your Old Dog
12-19-2005, 07:27 PM
Great job! Don't let your ego get the better of you and start flashing it around the salvage yard you found it at! I can see things getting pretty expensive for you! Really a great job you've done there.
C - ROSS
12-19-2005, 07:46 PM
Great find and a super job. The local junk yards will have to look out, I'm gonna be watching.
Now I just have to find out how to get that paint into the tank, will save a lot of work.
Ross
CCWKen
12-19-2005, 07:48 PM
Mark,
I don't have pictures of the mess out of the tank. When it comes out, everything is covered in black iron, including the aluminum and brass. Don't let dry! All you have to do is wash the black off. Water and a paint brush work.
I put the whole thing in the tank. No need to remove brass or aluminum parts. The only affect is a slight dulling. The etching is so light, it's not worth the chance of breaking a screw getting them off. They polish up easily. And yes, the rust under the brass was converted/removed. At least under the larger scale--It was the only one I removed to polish. I didn't try to remove the smaller 0- indicator.
I just used a buffer on the aluminum parts.
This is how the parts looked after disassembling and drying.
http://img.photobucket.com/albums/0903/CCWKen/Tools/Machine/Radius/Radius-Tool-After-002.jpg
aboard_epsilon
12-19-2005, 07:56 PM
Great job and pics of what I wanted to see thanks.
so it frees up the corroded and seized parts as well...brillient....saves a lot of time.
what would be the smallest charger you could use on a job like yours ...I only have a 6 amp one.
all the best.mark
BillH
12-19-2005, 07:58 PM
Beutiful, good find, good job.
CCWKen
12-19-2005, 08:14 PM
Hey Mark, I think it would depend on how large of an item you're trying to clean. This piece weighed 22lbs. and has quite a bit of surface area. It was drawing about 10amps. (My meter is off a little)
http://img.photobucket.com/albums/0903/CCWKen/Tools/Machine/RadiusTool005.jpg
MikeyR
12-20-2005, 09:39 AM
WOW! Great job! I gotta build me one of those tanks. Wouldn't have believed it iffin I hadn't seen it.
aboard_epsilon
12-20-2005, 10:32 AM
Yup and I've got to go out looking for big second hand start/chargers like Kens.
all the best.mark
Cecil Walker
12-20-2005, 11:04 AM
Great job Ken, congrats on the find.
flatlander
12-20-2005, 02:01 PM
In this day & age of the 'throw-away' society, it's a real pleasure to see what a knowledgable & industrious fellow can do with a piece of what ordinary folks would consider junk. Makes me want to head for the nearest scrap yard and start digging for 'gold'. Nice job. Where would I find information on building an electrolysis tank?
CCWKen
12-20-2005, 06:10 PM
Hey Flatlander, Evan did a whole series a while ago. If you do a Google on Electrolytic Rust Removal , you'll probably get thousands of pages. Around 26,000! http://bbs.homeshopmachinist.net//biggrin.gif
hsmike
12-20-2005, 07:42 PM
Ken,
What was the solution you used ? That is amazing!
JRouche
12-20-2005, 07:55 PM
Ken, real nice. Makes me heart full knowing the fine tool got another life.
Are the knurled wheels aluminum or SS? They really didnt get that bad and turned out great. JRouche
CCWKen
12-20-2005, 08:10 PM
JR, the knurled wheels in the back are aluminum. The scales on the side are brass. There's also a bronze nut for the radius screw. All I did was wire-wheel a spot on the base to make a good connection and lowered the whole thing into the tank.
Mike, the electrolyte is Sodium Carbonate--Arm & Hammer "Super Washing Soda" if you do the shopping. http://bbs.homeshopmachinist.net//biggrin.gif
freddycougar
12-20-2005, 08:49 PM
VERY NICE.. xcelent workmanship....
freddy
Rustybolt
12-20-2005, 10:27 PM
WOW!! Beautiful.
12-20-2005, 11:47 PM
Sure looks nice. I have used my tank to clean up aluminum that was stored with a bunch of rusty steel. That works pretty well.
Here is the link to the thread on derusting:
http://bbs.homeshopmachinist.net//Forum1/HTML/013558.html
abn
12-20-2005, 11:50 PM
Nice work!!
SJorgensen
12-20-2005, 11:57 PM
That is a great looking tool. It is so much the better that you've found a diamond in the rough and then made it back into a diamond.
Thanks for showing how well it can be done.
