View Full Version : Dressing a CBN wheel???
koolisj
01-04-2006, 12:24 PM
To dress the wheel to it's hub you should use a ???
To clean the wheel after uses you should use???
Does anyone have any good suggestions on what type of wheel to use for gringing nickel-titanium???
CCWKen
01-05-2006, 12:33 AM
Is this a test?
Diamond on the side, Aluminum Oxide on the face. Grind wet-Face wet, Grind dry-Face dry.
Can't help ya on the NiTi. Sounds like the stuff they make eyeglass frames out of. "Memory Metal".
