Anyone ever made a hydraulic home made bench press for bearings etc and are there any plans floating about.I can buy a nice bottle jack ten tons or so quite cheaply so any advice would be helpful also I have a trolley jack sitting here doing nothing as I am now beyong car repairs can that be hacked down for use ?Alistair
Hydraulic home made press??
This one was home made, Ibeam wrapped around, two linear slides holding ram in alignment, 5hp pump, electric solonoids.
Do you remember seeing he HSM article about a year or so back?
If you have Harbor freight, they have one that goes on sale for $150 at times, as good of a small one as you can get. It will press out the case on a harley in a minute.Excuse me, I farted.
........Alistair, I made one several years ago. I scribbled a design out then went to the metal dealer and bought the steel channel and had them make the 5 cuts to my lengths. My dad had a 225 Amp Lincoln (doesn't everyone?) and I welded it up. A couple tabs welded on the top and on the ram plate hold the springs to retract it. It just holds a 12 ton bottle jack.
The hardest part was drilling the holes to take the pins for adjusting the table up and down. It's about 3 times the weight of any other bench type hydraulic press I've ever seen, ha! Those 'consumer' types are all sheet metal compared to mine.
RickSon of the silver stream ..... Bullet caster.
I had a square one, it was made of 4" channel. I put a hydraulic jack in it to press out universal joints in cars. Built a 3" brake to go in it. (bending copper bus)
It don't take a lot if the side to side wobble don't hurt anything. Making one exact is a art.Excuse me, I farted.
Alistair,
Happy to oblige. I was inspired by the plan for the hugh one in Home Shop Machininst about a year ago and used what I had around. I works good, but one mistake I made was using square tube for the vertical columns. It should have pairs of flat bar or angle or chanel with space between for the movable beam and the workpiece (if it is long). If you know any Hanlan's over there in the old country tell them we made it OK.
[This message has been edited by gkman11 (edited 01-13-2006).]
30/50 ton plans page 20 may/june 2004 HSM
Glen
Been there, probally broke it doing thatGlen
Alistair
Here is one I made a few years ago which is very compact & utilises a 12 ton bottle jack, width between the uprights is "15 with 17" max beneath the ram. A feature that proves very useful is that the ram slides sideways by 3" each way.
If you would like more detail or dimensions I would be happy to oblige.
regards
check this site out and the other post on a small press with threaded rod supports.
The primary focus of our WebSite is HYDRAULIC JACKS and related equipment - The different types, uses and capacities, along with their general history, manufacturers and tips on buying and care of.
Norco offers a broad selection of high-quality American made and imported professional shop equipment covered by a limited lifetime warranty.
Glen
