Phil B
09-05-2001, 11:07 AM
I have a question about the aftermarket table feed drives that are used to move the cross feed tables on mills. "here is an example of one: http://grizzlyindustrial.com/fcgi-bin/lookup.fcgi/products/lookup.cfg?q=item&kw=G5964
I'm investigating using one on an ornamental woodworking mill; reason being it looks like it would work and they are significantly cheaper than the motor drives sold for my machine by the manufacturer ($800). For a look at what I'm talking about see http://benchmark.20m.com/tools/LegacyMill/LegacyWalkaround/LegacyWalkAround.html
I've already looked at the table feeder torque / speed range and it looks compatible to my machine.
My questions are:
1. How is the movement stopped; do these have clutches in them or is there a switch involved that actually removes power from the motor?
2. Do you think they would live running continuously? I could probably use them 2 or 3 hours straight. It wouldn't be any problem for me to install a muffin to provide cooling air.
3. Does the feed direction lever physically engage direction changing gears or is it just a switch that reverse motor polarity?
PMB
My questions are:
PMB
