I will need to drill some 61-62 Rockwell C steel at work. I have ordered a carbide drill bit from J&L rated to drill up to 65. Do you guys have any experience with this? What speed, how much pressure, do I expect a continous chip or powder comming off the bit? Use cutting lube? I have Molly D, recomemded for tough to cut metals such as stainless and titainium. This is not a production deal, for now just one 11/32 hole to take the head of a #12 socket head screw, to locate a part in a machine that is worn where it is supposed to locate. I can use one of the bridgeports in the tool room, which are in good condition, for this operation. Thanks for any advise that will help this to be successfull.
Tom
Tom
