View Full Version : Dumore 5-021 8072
LTC67
02-14-2006, 09:39 AM
I picked up a Dumore 5-021 8072 1/2 hp T.P. Grinder and I only have 2 of the 5 pulleys, are there any O.D. specs for pulleys 1 thru 5 available, so I can determine the 3 that are missing. As well I need the operating manual, grinding wheel guard, stone with washers, and spare belt.
If these are available please tell me where they can be purchased, I'm in the Memphis TN..
Thanks for your time,
SGW
02-14-2006, 11:03 AM
You ought to be able to get everything direct from Dumore. I hear their customer service/support is excellent, even for old products. (Of course you PAY for that excellent service/support....)
WLW-19958
02-14-2006, 12:19 PM
Hi There,
I don't have spec.s for the old Dumore #5 but the #5 and the #7 were combined into the Dumore #57 model. The models #5 and #7 were the same machine except for the hp. of the motor (#5 - 1/2 hp.; #7 - 3/4 hp.). The pulleys for the model 57 are:
No:..........Size
1............0.985"
2............1.985"
3............2.975"
4............3.985"
5............5"
75...........0.735"
1.2..........1.235"
The last two are "special purpose" pulleys and are not part of the standard toolpost grinder kit. I include them for completeness (not knowing what pulleys you are missing). Pulleys usually have the number stamped on them in the hollowed-out area (at least mine are).
I hope this helps. Good Luck!
-Blue Chips-
Webb
