View Full Version : 4130
rbregn
12-05-2002, 02:23 PM
I'm thrying to find a piece of 4130 that is 2.5" od by 1.5" id 12" long. Anyone have any sources? Yes I did the google search,so don't suggest that!
Thanks
Rob
Rotate
12-05-2002, 02:36 PM
You may have to get 2.5" round bar and bore it out. 2.5OD and 1.5"ID doesn't sound like something you can get off the shelf.
Albert
Allmetal
12-05-2002, 05:20 PM
Try Speedy Metals out of New Berlin, WI. They have a toll free # 1-888-744-4140. I have bought some 12L14 from them but they should have 4130 also plus they were reasonable for small orders as well as shipping. They have stuff on e-bay but found it cheaper to just order direct.
Tibertus
12-05-2002, 06:47 PM
Hopefully this won't set you off, but I found lots of information and some places that sell 4130 by going to www.dogpile.com (http://www.dogpile.com) and searching for 4130. Its a good search engine that I have a lot of luck with. Give it a try and see if that helps.
Best of luck and happy holidays.
Thrud
12-05-2002, 10:14 PM
Rob
Any steel distributor should be able to get it for you. I got 8" seamless 1" bore high pressure pipe from a local distributor. It should be easier to find in the Chicago area - check with US Steel.
Do a search on www.thomasregister.com (http://www.thomasregister.com)
rbregn
12-06-2002, 12:16 AM
Sometimes you just have to post it for the doors to open! I've been looking for a month and the largest i've found is 2". So I figure I would see if anyone out here had a source. after I posted my inquiry I've found 3 places so far!
Thanks for the help, maybe I'll even find some closer then 1000 miles! If not at least I've found some.
Rob
INTP
12-09-2002, 01:15 AM
metalmart.com is a decent source for small amounts of all sorts of metals. cut to the nearest inch.
