View Full Version : Backplate
SprintCarDriver
12-09-2002, 09:21 AM
A while back there was a thread that recommended a company that had unfinished backplates. I have searched but with no luck. Anyone remember or know the name of the company? Thanks
Larry Nicks
12-09-2002, 10:15 AM
Look here
http://www.victornet.com/
"The usual suspects" (Travers www.travers.com, (http://www.travers.com,) MSC www.mscdirect.com, (http://www.mscdirect.com,) etc.) carry Bison backplates.
Dick Payne
12-09-2002, 07:01 PM
Sprint car driver:
I was involved in a thread on looking for a source for cast iron for back plates and someone suggested Victor Machinery (see above site posted by Larry Nicks) They have a 6" by 1/2" thick rough back plate for $12.50. I have made two out of cast iron free weights that turned out ok. The reason you probably didn't find the other thread is that I mistyped cast iron and couldn't chang it so numerous responces said "cast iton" (I think).
I paid about $6 for the 10# cast iron free weights at Big 5 Sporting Goods here in California.
Dick
Thrud
12-09-2002, 11:00 PM
SprintCarDriver:
The Bison brand backplates are high quality cast iron, well seasoned, and well worth the money. If you have a threaded nose and want the best fit get an unmachined blank to fit it perfectly to your spindle. For the taper lock type(A & L spindles) and the Camlock (D1-4 etc.) buy the semi-finished. They are properly machined to fit the spindles and will only require machining the backplate surface to mount the chuck only.
