View Full Version : Will 'SK 30' taper fit '30 int'?
benharker
03-14-2006, 02:26 AM
Does anyone know if an SK 30 tool will fit in a mill that has an 30 int taper?
Thanks,
Ben H
Milacron of PM
03-14-2006, 10:09 AM
Same taper but I think SK is like CAT or BT in that it will be meant to receive a pull stud and therefore won't have the straight neck of a standard no. 30. Still might could use the SK in a standard no. 30 machine but might need longer drawbar and might need metric threads on said drawbar.
CAT 40 for example can be used in a standard no. 40 machine if the machine has a long enough draw bar, as both CAT and standard 40 have 5/8-11 internal threads.
benharker
03-14-2006, 11:12 AM
As far as I know SK 30 does have an internal thread. I can make a drawbar to suit no problem. My main concern is if the taper will fit. Thanks for the reply D.
Ben
