Challenge: To virtually tool up this milling machine taking into consideration the limited budget of the average home shop user.
Objective: To virually "purchase" tooling that fits this particular machine. Making this machine as versatile as possible. The tooling should provide the most "bang for the buck". As is the case in most real life situations, the tooling will have to be a compromise between quality and price.
Those who wish to participate must supply a direct link to the tooling they wish to add to the machine. You may also wish to describe the versatality of the tooling you add. IE. the operations that can be done with the addition of your tooling.
This should be a FUN excersise. Political opinions about purchasing Asian tools should be posted elsewhere. Theres plenty of THOSE threads out there. So lets keep it fun!
Here is the machine we will be outfitting:
Here are the specifications:
Specifications:
* Spindle taper: R-8
* Spindle travel: 3"
* Max. distance spindle to table: 12-1/4"
* T-Slots (3): 3/8"
* Table size: 6-1/8" x 26"
* Max. longitudinal travel: 15-5/8"
* Max. cross travel: 6"
* Max. drilling capacity for cast iron: 1"
* Max. drilling capacity for steel: 3/4"
* Head tilt: 45آ° R & L
* Ram swiveling angle: 360آ°
* Number of speeds: 9
* Range of speeds: 240-2760 RPM
* Motor size: 1-1/2 H.P.
* Packing size with stand: 40-15/16" x 34-1/4" x 76-3/4"
* Approx. shipping weight: 980 lbs.
Specifications:
* T-Slots (3): 3/8"
