Jon H
03-11-2001, 08:09 PM
Hello Group
Just joined up. My name is Jon Hintz. I live in Champlin MN
I have a Craftsman 6" lathe and a Sherline mill. My primary interst is in Miniature Weapons. I am a novice builder for several years now.
A question for the group.
Does anyone know how to make small (very small) flat springs? These would be used as a hammer spring in many older derringers. I have used bobby pins for the springs in the past on the smaller scale weapons I have made
I am going to a little larger scale and would like to be able to make a stronger spring to operate the actions correctly. I have some carbon steel that has been annealed so it can be worked and tempered. What is the correct way to temper this? I purchased a flat spring material package from Blue Ridge Machinery with several thickness of this material. Can this stuff be ground,filed, bent etc. and then tempered?
Thanks,
Jon Hintz
Thanks,
Jon Hintz
