12-03-2003, 12:08 PM
A couple of simple things to make Google work better for you:
If you are searching for something and you get a lot of hits on unrelated sites because they also contain some of the search terms you can subtract them from the results. Say you are searching for "lathes" and you get a lot of hits on wood lathes. You don't want wood lathes. To filter out wood lathes you would put in the search terms "lathes -wood", not including the quotes. Using the minus sign will cause all pages with the word wood to be discarded from the results. If you use a plus sign before the search term it means the results MUST contain that term. If you put a phrase in quotes it means the entire phrase MUST be present.
