sidneyt
08-17-2001, 12:33 AM
I am not sure what they send in the way of tools with your Shoptask, but if you will very shortly wear them out, you must be doing some machining.
I would agree that using HSS is definitely the tool of choice especially for brass and aluminum. I have never used 4130, but I am sure it will work fine with that too. IF you are somewhat new to grinding tools you can practice with some CRS square stock or you can buy something less expensive than Cleveland Mo-Max from Enco, etc. I have have used a variety of Chinese, Indian, Korean HSS all with good results, once again with brass and Al. When it comes to steel (I am usually dealing with 1018 or 1045) the inexpensive brazed on carbide tool bits are handy for roughing followed with the HSS finishing tool.
Another point is that just because you have 1/2" tools now doesn't mean you can't use 3/8" HSS when you grind them yourself. It will save yourself some time and grinding wheel to use the smaller size tool and yet you will suffer no loss of machining ability. Yes, it you are using your Shoptask to take big bites off of 4130 round (>.25") then I would probably say the 1/2" tool size may be preferable, but then I would probably just use a cheap brazed on tool for that purpose.
Once I got the hang of grinding HSS tool bits I would not hesitate to grind a differenct one for a new project. This was made easier by using the smaller 3/8" size tool size. I must have ground over two dozen tools not counting boring bar tool bits (a somewhat different challenge).
S. Teague
12 x 36 lathe and mill/drill building model engines.
S. Teague
